Problem this snippet solves:
Hi Folks,
the iRule below allows you to extract persistence cookie information as defined in SOL6917.
The provided iRule has support to extract persistence cookie information for:
- IPv4 pool members
- IPv4 pool members in non-default route domains
- IPv6 pool members
- IPv6 pool members in non-default route domains
The iRule stores the extracted information in the variable
$lb_select
in a
[LB::select]
compatible format as outlined below.
pool /Common/MyPool member 10.0.0.1 80
pool /Common/MyPool member 10.0.0.1%1 80
pool /Common/MyPool member 2001:0112:0000:0000:0000:0000:0030:0030 80
pool /Common/MyPool member 2001:0112:0000:0000:0000:0000:0000:0030%1 80
Cheers, Kai
How to use this snippet:
Integrate the provided code in your iRule to extract and analyse persistence cookie information.
Tweak the
$pooland
$cookie_namevariables as needed to match a hardcoded pool and your custom cookie names.
Access the
$lb_selectvariable to extract the persistence cookie information.
Enjoy!
Code :
# Setting the currently selected pool and cookie name
set pool "[LB::server pool]"
set cookie_name "BIGipServer[getfield $pool "/" 3]"
# Inject the persistence cookie test values as outlined in SOL6917
# IPv4 route domain disabled cookie value
# HTTP::header replace "Cookie" "BIGipServer[getfield $pool "/" 3]=1677787402.36895.0000"
# IPv6 route domain disabled cookie value
# HTTP::header replace "Cookie" "BIGipServer[getfield $pool "/" 3]=vi20010112000000000000000000000030.20480"
# IPv4 route domain enabled cookie value
# HTTP::header replace "Cookie" "BIGipServer[getfield $pool "/" 3]=rd5o00000000000000000000ffffc0000201o80"
# IPv6 route domain enabled cookie value
# HTTP::header replace "Cookie" "BIGipServer[getfield $pool "/" 3]=rd3o20010112000000000000000000000030o80"
# Trying to extract the persistence cookie value
if { [HTTP::cookie value $cookie_name] ne "" } then {
# A persistence cookie value is found. Enumerate the format of the persistence cookie value.
switch -glob -- [HTTP::cookie value $cookie_name] {
"rd*00000000000000000000ffff*" {
# The received persistence cookie has an route domain enabled IPv4 format
if { [scan [HTTP::cookie value $cookie_name] {rd%do00000000000000000000ffff%2x%2x%2x%2xo%d} rd oct1 oct2 oct3 oct4 port] == 6 } then {
# The received persistence cookie is well formated. Contructing the lb select string.
set lb_select "pool $pool member ${oct1}.${oct2}.${oct3}.${oct4}%$rd $port"
# The received persistence cookie is malformated.
set lb_select ""
"rd*" {
# The received persistence cookie has an route domain enabled IPv6 format
if { [scan [HTTP::cookie value $cookie_name] {rd%do%4[0-9a-fA-F]%4[0-9a-fA-F]%4[0-9a-fA-F]%4[0-9a-fA-F]%4[0-9a-fA-F]%4[0-9a-fA-F]%4[0-9a-fA-F]%[0-9a-fA-F]o%d} rd group1 group2 group3 group4 group5 group6 group7 group8 port] == 10 } then {
set lb_select "pool $pool member ${group1}:${group2}:${group3}:${group4}:${group5}:${group6}:${group7}:${group8}%$rd $port"
set lb_select ""
"vi*" {
# The received persistence cookie has an route domain disabled IPv6 format
if { [scan [HTTP::cookie value $cookie_name] {vi%4[0-9a-fA-F]%4[0-9a-fA-F]%4[0-9a-fA-F]%4[0-9a-fA-F]%4[0-9a-fA-F]%4[0-9a-fA-F]%4[0-9a-fA-F]%[0-9a-fA-F].%d.} group1 group2 group3 group4 group5 group6 group7 group8 port] == 9 } then {
# The received persistence cookie is well formated. Extracting the port information
set port [format %04x ${port}]
set port [expr { "0x[string range $port 2 3][string range $port 0 1]" }]
# Contructing the lb select string.
set lb_select "pool $pool member ${group1}:${group2}:${group3}:${group4}:${group5}:${group6}:${group7}:${group8} $port"
set lb_select ""
# The received persistence cookie has an route domain disabled IPv4 format
if { [scan [HTTP::cookie value $cookie_name] {%d.%d.} ipv4 port] == 2 } then {
set port [format %04x $port]
# Extracting the IPv4 octets and contructing the lb select string.
scan [format %08x $ipv4] "%2x%2x%2x%2x" oct4 oct3 oct2 oct1
set lb_select "pool $pool member ${oct1}.${oct2}.${oct3}.${oct4} $port"
set lb_select ""
default {
# The received persistence cookie has an unknown format
set lb_select ""
# The current request does not provide a persistence cookie
set lb_select ""
# Log the extracted cookie information
log local0.debug "Cookie Persistence Info: $lb_select"
Tested this on version:
12.0
