Persistence Cookie iRule not working as desired
if { [HTTP::path] equals “/api/v1/sendpinonceoff” } {
HTTP::path /sendpinonceoff
pool MM-MEPD
persist none
if { [HTTP::path] equals “/api/v1/verifypinonceoff” } {
HTTP::path /verifypinonceoff
pool MM-MEPD
persist none
if { [HTTP::path] equals “/api/v1/processrefund_status” } {
HTTP::path /processrefund_status
pool MM-MEPD_Deliver
persist none
if { [HTTP::path] equals “/api/v1/processrefund” } {
HTTP::path /processrefund/
persist none
if { [HTTP::path] equals “/api/v1/sendpinajax” } {
pool MM-MEP
persist cookie insert “MM-MEP-SENDPIN”
Now when I go to the url /api/v1/sendpinajax, I see the cookie MM-MEP-SENDPIN. The problem is I also see the default persistence cookie set for the Virtual Server. Is this desired behavior?
this is mine. is there any different?
[root@iris:Active] config  b virtual bar list
virtual bar {
   snat automap
   pool foo
   destination 172.28.17.33:http
   ip protocol tcp
   rules myrule
   persist cookie
   profiles {
      http {}
      tcp {}
[root@iris:Active] config  b pool foo list
pool foo {
   members 10.10.70.110:http {}
[root@iris:Active] config  b profile cookie list
profile persist cookie {
   mode cookie
   mirror disable
   cookie mode insert
   cookie name none
   cookie expiration immediate
   cookie hash offset 0
   cookie hash length 0
   rule none
[root@iris:Active] config  b rule myrule list
rule myrule {
        persist cookie insert "cookieirule"
[root@iris:Active] config  curl -I http://172.28.17.33/
HTTP/1.1 200 OK
Date: Wed, 02 Nov 2011 08:50:42 GMT
Server: Apache/2.0.59 (rPath)
Last-Modified: Sat, 11 Jun 2011 00:31:47 GMT
ETag: "667a-67-cfb682c0"
Accept-Ranges: bytes
Content-Length: 103
Vary: Accept-Encoding
Content-Type: text/html; charset=UTF-8
Set-Cookie: cookieirule=1850083850.20480.0000; expires=Wed, 02-Nov-2011 17:43:31 GMT; path=/
nitass- you dot have multiple pools like I have in the iRule. But I understand that you have a default persistence cookie profile which does not have unique name and then you specify a cookie name in iRule. According to my situation you should be seeing 2 cookies, one which has the default cookie name BigipServerpool and the second cookieirule. But you are seeing only one, which is desired.
Do you see nay explicit error in my iRule?
I
please try this.
pool MM-MEP
persist none
Regards
Kurt Knochner
Do you see nay explicit error in my iRule? i don’t see any suspicious in the irule. have you tried Kurt’s suggestion? how is it?
by the way, would it be possible to paste output of curl command?
nitass- this is what I see in curl
curl -lv http://172.19.11.73/api/v1/sendpinajax
* About to connect() to 172.19.11.73:80
* Connected to 172.19.11.73 (172.19.11.73) port 80
> GET /api/v1/sendpinajax HTTP/1.1
User-Agent: curl/7.10.6 (i386-redhat-linux-gnu) libcurl/7.10.6 OpenSSL/0.9.7a ipv6 zlib/1.1.4
Host: 172.19.11.73
Pragma: no-cache
Accept: image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, */*
< HTTP/1.1 404 Not Found
< Date: Thu, 03 Nov 2011 14:26:22 GMT
< Server: Apache/2.2.3 (CentOS)
< Content-Length: 293
< Connection: close
< Content-Type: text/html; charset=iso-8859-1
< Set-Cookie: MM-MEP-SENDPIN=218764204.20480.0000; path=/
404 Not Found
Not Found
The requested URL /api/v1/sendpinajax was not found on this server.
Apache/2.2.3 (CentOS) Server at 172.19.11.73 Port 80
* Closing connection 0
[aladkani@mmusbox-lx01 aladkani]$ curl -lv http://172.19.11.73/api/v1/processrefund
> GET /api/v1/processrefund HTTP/1.1
Host: 172.19.11.73
Pragma: no-cache
< HTTP/1.1 400 Bad Request
< Content-length: 22
< Date: Thu, 03 Nov 2011 14:26:53 GMT
* Connection 0 left intact
This looks as desired because curl unlike browser is not keeping the session open. The problem is with browsers.
Now I was following this article to circumvent this issue,
So according to this KB if I use default cookie name BIgipServer, this confusion with cookie persistence while pool jumping will not happen.
BUT, i have one url for which I am doing persist none. I want to know what happens to that in this case. In short user goes to url /blah1 which has persistence gets cookie BigipServerBLAH1, and then if it goes to url /blah2, which has persist none in the profile, what happens there. I do not think persist none will make the browser drop cookies.
Also I cannot try what Kurt said, doing persist none and then cookie insert because what if the user goes back to the pool where default cookie is used. I am not sure if I am explaining my case properly here.
I really appreciate the time you guys have put in replying.
No, that’s not possible, but it will tell the LB to ignore any persistency records for that connection.
Well, if you set the cookie for /blah2 it will be valid for the whole domain (I’m not sure if the LB will take care of the path argument in a cookie). So, the cookie set for /blah2 will also be sent (by the browser) for /blah1 and the LB will use the persistence information stored in that cookie, EXCEPT you tell it to ignore persistency for /blah1 by using “persist none”. I think I misinterpreted your frist request and iRule.
I think the iRule in your first post is not telling the whole story, and I believe we need some examples (URLs) and descriptions what the LB should do in those cases.
Regards
Kurt Knochner
Kurt, this is the current iRule
pool MM-MEPD
pool MM-MEPD
log local0. "[IP::client_addr]:[TCP::client_port]: this is the path [HTTP::path] "
HTTP::respond 200 content “HTTP path [HTTP::path]\n\n”
HTTP::path /sendpinajax
pool MM-MEP
Now this Virtual Server so far has non default persistence profile. And as you see depending on the urls in irule we decide on the pool.
Now our site will start hosting 2 new API calls which will have specific urls, For thise calls we need persistence. To add persist cookie command in the iRule I need to add a default cookie profile on Virtual server.
This starts the chaos. After adding default profile I will have to add “persist none” for all urls in this current irule..correct?
Then for the other 2, I can have the default persistence profile take care of the persistence as they will use same pool to server api call.
This is the background.
Thanks again.
In the irule that I have posted above do not consider this part,
pool MM-MEP
have not added that yet in production. This is just for testing.
Not necessarily. You can use “persist cookie” only for those URLs.
Not necessarily. See above.
Then for the other 2, I can have the default persistence profile take care of the persistence as they will use same pool to server api call. This is the background.
Let’s do it the other way round. Just use “persist cookie insert xxxxx” for those api urls.
That “should” work, UNLESS the client uses HTTP 1.1. The reason: persistency works for TCP connections. If a client uses HTTP 1.1 it might use the same TCP connection for several HTTP requests. In your example: one request to the new api, which will be persisted and another request to something, which will be persisted as well, as it’s the same TCP connection. In that case a ONECONNECT profile might help, as that will de-multiplex the client request. However I’m not sure if persistency will be handled appropriately with ONECONNECT. Please try that.
Regards
Kurt Knochner
Kurt,
If you add persist cookie in iRule for Virtual Server which does not have a default persistence profile, you get this error
01070372:3: Persistence mode (Cookie) called out in rule (MEP_rewrite_v2) requires a corresponding persistence profile for virtual server (MM-MEP-HTTP).
O.K. I have not tested it, so you’ll have to do it the other way round :-)) Sorry for that.
Can you please try this?
persist none
 all the other stuff
if { [HTTP::path] equals "/api/v1/sendpinajax" } {
HTTP::respond 200 content "HTTP path [HTTP::path]\n\n"
pool MM-MEP
persist cookie insert "MM-MEP-SENDPIN"
BTW: do you know if the clients are using HTTP 1.1?
i understand persistence profile is required when using persist cookie command.
by the way, i agree with Kurt’s irule, i.e. setting persist none first and then specifying custom persist cookie on specific url, since your irule does not set persist none on url which does not match those conditions.
additionally, utilizing if/elseif instead of series of if clause would be good.
e.g.
if {…} {
do something
} elseif {…} {
do something
} elseif {…} {
do something
do something
Guys thanks for all the help. I will use persist none in for the urls where I do not need persistence and default persistence profile for urls where i need persistence. I am doing this because I am sure in future we will have urls wich will select new pool members and the KB article which I pasted above talks about this limitation , that if we have an iRule which selects differnt pools with non similar pool members, persistence fails unless we have default cookie name.
Also as Kurt mentioned if the same TCP session is used to do a Get requet for a new url persitence will not work as desired because it is based on sessions. I noticed that while testing from my browser, so when I was jumping from one url which had persistence to one which did not have, I was not getting right pool member until i hit rtefreshed once or twice, which I guess in the back opens a new TCP socket and the persistence selection logic kicks in.
Thanks again.
Also as Kurt mentioned if the same TCP session is used to do a Get requet for a new url persitence will not work as desired because it is based on sessions. I noticed that while testing from my browser, so when I was jumping from one url which had persistence to one which did not have, I was not getting right pool member until i hit rtefreshed once or twice, which I guess in the back opens a new TCP socket and the persistence selection logic kicks in. if i’m not wrong, Kurt may want to mention this sol.
sol7964: Persistence may fail for subsequent requests on Keep-Alive connections
nitass.. :slight_smile: I tried oneconnect on my profile and I like it ..It solves the problem when I am changing urls w/o closing browser which have different persistence behavior according to the iRule
