Persistence based on several criteria
We are trying to manage Tibco to Siebel load balancing. Any suggestions would be appreciated. Below are the requirements as stated by the application owners:
Persistence is required since Tibco creates an application-level session, but source IP:Port persistence isn’t sufficient, as source port can change without application session closing.
To account for that event, the example below, evaluated in order, searches for a string in the TCP data which contains a specifier for the exact Siebel server that owns the application session.
When a TCP connection occurs:
If the TCP payload contains “/pcrm” and “/!3” use pool procrm05pool and set persistence to client IP:Port
Else if the TCP payload contains “/pcrm” and “/!b” use pool procrm06pool and set persistence to client IP:Port
Else if the client IP:Port is already in the persistence table, persist according to current status in persistence table
Else use default pool and set persistence based on client IP:Port
Same example provided by the application owners:
→ Example code to manage Tibco → Siebel load balancing
If (TCP:Payload contains “/pcrm” and “/!3”)
Then
Route to procrm05 pool
Set IP:Port persistence to procrm05 server pool
Else If (TCP:Payload contains “/pcrm” and “/!b”)
Then
Route to procrm06 pool
Set IP:Port persistence to procrm06 server pool
Else
If (IP:Port combination is already in persistence table)
Then
Route per persistence table status
Else
Route to default pool (load balance over both servers)
Set IP:Port persistence to chosen server
End If
End If
Here is what I have so far… (syntax is correct, but not sure if it will work)
when CLIENT_ACCEPTED {
TCP::collect
set client_exists ([IP::client_addr]:[TCP::client_port]) }
when CLIENT_DATA {
if { [TCP::payload] contains “/pcrm” and “/!3”}{
pool procrm05pool
persist uie “[IP::client_addr]:[TCP::client_port]”
elseif { [TCP::payload] contains “/pcrm” and “/!b”}{
pool procrm06pool
elseif { [info exists $client_exists] }{
persist uie $client_exists
else {
pool defaultpool
Thank you so much Colin!! I will get with the Siebel application team and test this iRule.
I truly appreciate your quick response!!
Michael
I definitely will. Thank you for your assistance.
