Persistence at the Pool Level
I’m currently migrating from 4.6.X to 9.x. I’ve run into an issue with the way the 9.x Environment handles Persistence. In 4.X persistence was maintainable on the Pool Level. It appears in 9.X persistence is now held at the Virtual Server level. The irule I’m using is a simple HTTP_Request where based on what the URL starts with they are pushed to a a designated pool. (the persistence mode is simple) Here’s a sample:
  if { [HTTP::host] starts_with "81aarp"  } {
      pool wl81prod-aarp
  else { [HTTP::host] starts_with "aarp-crm"  } {
      pool wl81prod-aarp1
What appears to be happening is since the persistence is held at the server level,
When users get redirected to a second pool within the persistence window, big-IP wants to push them back to the original pool and everything appears to hang.
Any ideas how we can configure 9.X to process the same as 4.X?
You can specify a different persistence profile in each condition in the rule, along with the pool.
   if {[string tolower [HTTP::host]] starts_with "81aarp"}{
       pool wl81prod-aarp
       persist source_addr 255.255.255.0 300
   } elseif {[string tolower [HTTP::host]] starts_with "aarp-crm"}{
      pool wl81prod-aarp1
      persist none
       take some default action
Check this post (Click here)
and the wiki page for the persist command (Click here) for more info.
Aaron
