persistence and NAME::lookup queries
All,
I’m trying to, upon HTTP request, determine if persistence already exists for a connection (using source IP) and use the pool that they are already using. If there is no persistence, I want do to a DNS lookup and then, based upon my answer, use a certain pool.
Here’s my rule as is:
Get the source IP address
set client_ip [IP::remote_addr]
Do a persistence lookup for the source IP
set persistence_pool [persist lookup source_addr $client_ip pool]
See if there’s already a session for the source IP and
use the pool already assigned
if { $persistence_pool ne “” } {
use pool $persistence_pool
Do the lookup
[NAME::lookup $client_ip]
when NAME_RESOLVED {
set in_my_domain [NAME::response address 0]
Direct to corresponding pool based answer
if { $in_my_domain ne “” } {
use pool HTTP_my_domain_pool
use pool HTTP_not_my_domain_pool
HTTP::release
I get the following in the ltm log:
TCL error: Rule HTTP_my_domain_check_rule - Prerequisite operation not in progress (line 5) invoked from within “persist lookup source_addr $client_ip pool”
so obviously I need to start something ahead of this persistence lookup I would imagine, but what? Any help greatly appreciated. I’ve searched and browsed a lot throughout here but I don’t see any specific references to using the persist lookup ability (other than the documentation example).
Please don’t be afraid to point out other errors throughout the script either. I can take it!
Thanks.
-madefiver
In the HTTP_REQUEST context I’m pretty sure you want to use IP::client_addr, not IP::remote_addr to lookup the persistence entry. Could it be that this is just a bad error message trying to tell you that it couldn’t find an entry? Hmmm, that shouldn’t error out though, just return null.
Strange. What version are you running? I’ll dig in to see if there are any pertinent CRs.
Colin
