Persistance problem
We have two APIs working behind F5. Our web app is working on F5 succesfully. Our problem is that we can’t ensure persistance when clients send XML requests to load balancer. For example, When we send open session request we take session from API1. After that we send second request with taken sessionid, f5 is forwarding it API2. then it returns “session not found”. My expactations is that when client take session from one node, F5 should forward all request same node until session closed or expired.
Have you tried adding a persistance profile? If so, what persistance profile are you using?
We are using cookie persistance and oneconnect is enable. We have not problem when using web app. on browser. If we try to directly send xml request to Load balancer, problem occurs.
Then you need to find something in the XML request to persist on. For example, see this post:
https://devcentral.f5.com/s/question/0D51T00006n8fAG/persistence-based-on-xml-data
Thanks for helping. We will try that.
