Basically it’s persisting based on the URI of a URL - specifically a query. 9 indicates what is skipped and 3 is the terminator. You can also use [HTTP::query] instead of [HTTP::uri] to accomplish this
Keep in mind we have HTTP::query and URI::query for accessing just the query portion of a URI as well. These would allow you to skip the findstr portion.
My logic: find ? in the URI, skip 9 chars to after the 3 and return the sub-string from there to the end, minus the terminator of length 3. So this is AD
I’m sure if I’m wrong the most excellent community will correct me.
Thanks nitass - looks like I was wrong. I did wonder if I should get on my test box to check…hence the delay in clicking on Submit and missing your post.
thanks very much .may i understand below : when skip 9 chars , it include the “?” ,so it start with the “?” , and end with “3”-------so the 9 chars are “?query123”, and then use the after 3 chars “ADF” to persist the session, does this true ? thank you !
