Persist uie question
Have an iRule that looks for an iPlanetPro Cookie and uses it to set persistance
persist uie $myLBCookie 1980
Question is will a pool member down take precidence over the persist statement, meaning if the pool member is down or goes down, will it still be directed to the down member before the timeout?
Is there a limit to the amount of sessions that LTM can remember?
We have a situation to where the VIP just quits, and the iRule
Larry Dalton
Hi Larry,
When a pool member is marked down, corresponding persistence entries seem to be removed from the persistence table. So when you use the persist command, the request will be load balanced and a new persistence record will be added.
See this post for a recent discussion of the details:
how to use persist lookup command
http://devcentral.f5.com/Default.aspx?tabid=53&aft=55954&afc=1172528
I don’t think there is a hard coded limit on the number of persistence table entries that can be added. I think it’s dependent on memory available. I’m not exactly clear on how much memory TMM allocates for persistence records or whether TMM will allocate more. Maybe someone can elaborate on this?
Your last sentence was incomplete. Did you have another question?
Aaron
Thanks Aaron, I think that answered my question.
Much appreciated.
:Larry
