Persist Question - noob Q
rule Persist_Universal {
persist uie [ findstr [HTTP::uri] “?” 8 3 ]
The issue I’m having with understanding the above is the “3”.
So as I understand, if I go to the following URL
http://www.anywhere.com/test.html?boat87897AD5B
The iRule looks for the ? then skips “8” characters/digits after the ? but what function/role does the 3 play?
here, 3 indicates 3 characters. So, the rule will search for “?” in the URI by skipping the first 8 characters and will look for it in 9th, 10th and 11th character.
When used with “3”, the rule searches till it finds the first “3” or till end of the string.
-Santosh.
Thanks! I know this was easy but I was stumped :slight_smile:
