I am stuck on how to reference the value of the x-forwarded-for header. we want to persist on the original client-ip. SNAT and the persistence profile is causing an upstream pool with 2 members to load-balance to only 2 members of a downstream pool that contains 4 members. source address affinity appears to be getting in our way so i thought if i could persist on the original client-ip, that would solve the problem. Just not sure how to reference the IP contained in the XFF header. Can you point me in the right direction?
when CLIENT_ACCEPTED {
Set persistence based on client IP for 900 seconds
persist uie “[IP::client_addr]” 900
