Persist on source IP and port
In a fast L4 server, can you persist on source IP AND tcp source port?
I cant see any information if you can do this.
I think you could use persist uie and [IP::client_addr]:[TCP::client_port]. If you get a parsing error for TCP:: commands with a FastL4 VS, you can use eval:
when CLIENT_ACCEPTED {
     Set persistence based on client IP:port for 3600 seconds
    set tcp_port_cmd "TCP::client_port"
    persist uie "[IP::client_addr]:[eval $tcp_port_cmd]" 3600
Else, this seemed to work for 9.4.7:
    log local0. "IP:port: [IP::client_addr]:[TCP::client_port]"
    log local0. "lookup: [persist lookup uie [IP::client_addr]:[TCP::client_port]]"
    log local0. "[persist uie [IP::client_addr]:[TCP::client_port] 3600]"
 when SERVER_CONNECTED {
    log local0. "lookup [persist lookup uie [IP::client_addr]:[TCP::client_port]]"
Aaron
