I have an application that returns URLs that look like this:
The “.6” at the end of the “sid=” string uniquely identifies the server. How do I create a rule to persist users with a .6 extention to a server with a specific ip address. For example all .6 URLs go to 10.10.10.6:80?
Assuming the sid=JSNd.fstR2gz5Y. is a static length before your Identifier of 6, and that the & is always the terminator, you can pull out the identifier and set it to a variable. Here’s a start:
if { [HTTP::cookie exists "persist_me"] } {
persist uie [HTTP::cookie "persist_me"]
when HTTP_RESPONSE {
set server_id [ findstr [HTTP::uri] "sid" 19 "&"]
You'll need logic here to compare the value of server_id
to the real server, and create new variable to insert into
cookie so when the HTTP_REQUEST is performed, no additional
processing will be required.
HTTP::cookie insert name persist_me value $server_id
If you just want to make sure you are persisting to the server responding, it might be easier to persist by extracting the responding server’s information:
if { [HTTP::cookie exists "persist_me"] {
set cookie_contents [HTTP::cookie persist_me]
set poolid [lindex cookie_contents 0]
set serverid [lindex cookie_contents 1]
set portid [lindex cookie_contents 2]
use pool $poolid member $serverid $portid
use pool $poolid
HTTP::cookie insert name persist_me value [LB::server]
