Hello,
I’m struggling with persistence. I have an application running on two ports (http and rtsp), the client first call the application via its http port where he sends his UID, a persistence entry is created to ensure he will use the same server for the second connection on port rtsp.
The first RTSP call contains the UID but all the subsequent calls don’t. They only carry a SessionID returned by the server after the first call. So I thought I could add a second persistence record when I receive the response of the server but if I use persist without add keyword, it has no effect and if I try with add keyword, it is rejected with the error :“[command is not valid in current event context (RTSP_RESPONSE)][persist add uie $SessionID $static::persist_timeout]”
Here is the code I’m trying:
when RTSP_REQUEST {
set UID [findstr [RTSP::uri] "UID=" 4 "&" ]
if { $UID != "" }{
persist uie $UID $static::persist_timeout
no UID, looking for Session Header
set SessionID [RTSP::header value "Session"]
if { $SessionID != "" }{
persist uie $SessionID $static::persist_timeout
when RTSP_RESPONSE {
Any help would be greatly appreciated.
Christophe
