Hi all!
I´ve been reading these two articles.
Are any of them a permanent fix for low diskspace of /var/ ? Or will we/I have to redo it after every upgrade?
/Kim
Hi all!
/Kim
This following article says you’ll have to do it again after an update.
/var folder size decreases automatically after upgrade (f5.com)
So there´s no permanent solution that survives an upgrade?
There doesn’t seem to be a permanent solution that survives an upgrade. However from version 16.0.0.0 the /var partition is increased by 50%. Maybe that will work for you. On the other hand, what’s eating your diskspace on /var?
Not sure, what´s eating it up to be honest. We got a case open, so hoping on some help there. As v16 is not supported on the new R-Series we´re skipping that i believe. So that leaves either V17 or V15 with this work each time…hmm
You can use ‘du -k -x /var | sort -n’ to see what directories uses a large amount of space. They are on the end of the list. That could give you an indication.
We checked alot now, but seems as we´re always around 79-80% full.. so after som talks with F5, expanding the mount is the best solution.
There IS a permanent solution that survives upgrades if you’re not willing to upgrade to v16. We successfully implemented it on v15.
It is effective from the first upgrade you do after implementing the config file.
Nice! Thanks for sharing.
Nice! But at this moment I think that ship has sailed for some environments, we have some 16 which will be upgraded to 17 in a near future.
But this is more or less what i was looking for.
