Periodic iCall script to auto-generate NodeIP-to-NodeName datagroup
Problem this snippet solves:
Hi Folks,
the iCall script and handler below can be used to auto-generate a NodeIP-to-NodeName datagroup on scheduled intervals. The auto-generate datagroup can then be used to resolve the
[LB::server addr]
output to the coresponsing node name label using the
[class match -value]
syntax.
Cheers, Kai
How to use this snippet:
  1. Tweak the periodic intervals (in seconds) of the iCall handler as needed.
  2. Import the provided iCall script and handler using the tmsh load config merge from-terminal syntax
  3. Take a look to the configured data-groups and LTM logfiles to verify the results.
  4. Use
    [class match -value [LB::server addr] DG_IP_2_NODENAME]
    within an iRule to resolve the name of a selected pool member.
Code :
sys icall script DataGroup_NodeIP_to_NodeName {
    app-service none
    definition {
        set nodelist ""
        set nodecounter 0
        # tmsh::log "iCall: Starting to enumerate existing node objects..."
        foreach partition [tmsh::get_config auth partition] {
            set partition "/[tmsh::get_name $partition]"
            # tmsh::log "iCall: Processing Partition: $partition"
            tmsh::cd $partition
            set nodes [tmsh::get_config /ltm node]
            foreach node $nodes {
                # tmsh::log "Processing Node : $partition/[tmsh::get_name $node]"
                append nodelist "\"[tmsh::get_field_value $node "address"]\" \{ data \"[tmsh::get_name $node]\" \}\n"
                incr nodecounter
            # tmsh::log "Finished Partition: $partition"
        tmsh::cd "/Common"
        if { not ([tmsh::list /ltm data-group] contains "ltm data-group internal DG_IP_2_NODENAME") } then {
            tmsh::log "iCall: Created the data-group \"DG_IP_2_NODENAME\"."
            tmsh::create /ltm data-group internal "DG_IP_2_NODENAME" type "string"
            # tmsh::log "iCall: The DataGroup does exist."
        eval "tmsh::modify /ltm data-group internal DG_IP_2_NODENAME \{ records replace-all-with \{ $nodelist \} \}"
        tmsh::log "iCall: Updated the data-group DG_IP_2_NODENAME with \"$nodecounter\" entries."
    description none
    events none
sys icall handler periodic DataGroup_NodeIP_to_NodeName {
    first-occurrence 2016-09-12:00:00:00
    interval 60
Tested this on version:
12.0
Was practicing trying to use this on 15.1.3.1 (in my lab) and running into this error:
Script (/Common/NodeList_2_Datagroup) generated this Tcl error: (script did not successfully complete: ("10.10.101.1" unknown property
Don’t know quite enough about iCall to diagnose, maybe @Kai_Wilke  could hook us up with a fix? :slightly_smiling_face:
