Performance Metrics
We are currently troubleshooting a performance issues with one of the virtual servers configured on our BIG-IP 9.2.3.
When going direct, the response time of the web application is (most of the time) less than 1 sec. However, when we go through the BIG-IP, the response times is averaging about 10 secs. Both the BIG-IP and the Web server are on the same VLAN.
We are using the following profile:
profile tcp test_tcp {
defaults from websphere_tcp
time wait recycle disable
delayed acks disable
proxy mss enable
selective acks disable
limited transmit disable
rfc1323 disable
slow start disable
bandwidth delay disable
nagle disable
ack on push enable
We have captured tcpdumps and logged a call to the F5 support and suggested the following:
add the following lines to the bigip.conf:
1. route {
mtu 1420
gateway x.x.x.x
2. Enable “Proxy Maximum Segment”
It only improve the performance slightly.
We would like to know if the performance degradation is from the client to the BIG-IP or the BIG-IP to the web server. Can we get these stats using iRules?
Any help is appreciated.
What does the websphere_tcp profile look like? Is the client base on the WAN on LAN? We have tuned the default profile somewhat for our WAN clients, the values we have changed are below:
proxy mss enable
slow start disable
nagle disable
proxy buffer low 98304
proxy buffer high 131072
send buffer 65535
recv window 65535
FYI, enabling bandwidth delay can create instability on your standby unit if you mirror L7 traffic. CR67185 was created for this, unfixed as of this point.
Feel free to contact me offline if you need further assistance as the performance issue you are tracking down isn’t rules related.
citizen_elah,
thanks for your reply. Here’s what the websphere_tcp profile looks like:
profile tcp websphere_tcp {
defaults from tcp
proxy buffer low 131072
send buffer 65535
recv window 65535
We only have one unit (this is in DEV), therefore, we are not mirroring and L7 traffic.
We’re sure that this is not an iRule related issue but we would like to know if there are any performance metrics that can be used using iRules (logging TCP/HTTP stats) to narrow down possible issues.
