I followed the Deployment Guide for F5 with PeopleSoft Enterprise Applications . It has a basic http monitor setup; however, it doesn’t do anything. I need to configure the Send String and possibly the Receive String variables, but need help.
Here is my login for PeopleSoft http://f5testps.uw.edu/psp/pstst3/?..uageCd=ENG
I can actually login through F5, only if I disable the http monitor.
I tried GET /xmllink/E_REC/TCHH_WEB_DOWN_PAGE HTTP/1.1\r\nHost: f5testps.uw.edu/psp/pstst3/?cmd=login&languageCd=ENG&\r\nConnection: close\r\n
Any help would be appreciated.
Thanks,
Ty
