PDF's not displaying in ssl connection
I have a pool that makes a request to a second server in my networker request Data in a PDF formatt.When the request is sent back to the user if show up as a blank page.How can I use a irule to convert the back in connection from http to https so the user can see the Data in a PDF FORM?
What makes you think that this is an SSL issue? As far as I know there shouldn’t be any problem with transferring data on a backend connection in a different encryption state than the front-end connection. This sounds more like a data or formatting problem than an SSL one.
Colin
