Can someone provide a good LTM client cipher set that would pass PCI ASV as well as support as many browsers as possible? I know no one can support IE 6-10 due to it not having TLS 1.2 and still be PCI compliant…
Thanks!
Thanks!
Hello Nate,
These string configs may not be ideal, but are good enough to pass PCI audits. I’ve implemented them for many clients who undergo PCI audits annually.
PCI DSS 3.1 (Will be enforced in June 2016):
ALL:!EXPORT:!RC4:!DES:!ADH:!EDH:!SSLv3:!TLSv1
PCI DSS 3.0 (Enforced today):
I believe if your F5 version is v11.5.1 or later, the DEFAULT cipher string will also pass PCI DSS 3.0. For v3.1 compliance, you will have to additionally disable TLS 1.0
Regards
Hello Nate,
Regards
My problem is that this fails PCI via my VM scanner. I can eliminate TLS 1.1 but still leaves this: Negotiated with the following insecure cipher suites: TLS 1.2 ciphers: TLS_RSA_WITH_3DES_EDE_CBC_SHA TLS_RSA_WITH_AES_128_CBC_SHA TLS_RSA_WITH_AES_256_CBC_SHA TLS_RSA_WITH_AES_128_CBC_SHA256 TLS_RSA_WITH_AES_256_CBC_SHA256 TLS_RSA_WITH_AES_128_GCM_SHA256 TLS_RSA_WITH_AES_256_GCM_SHA384 TLS_RSA_WITH_3DES_EDE_CBC_SHA TLS_ECDHE_RSA_WITH_3DES_EDE_CBC_SHA TLS_RSA_WITH_3DES_EDE_CBC_SHA TLS_RSA_WITH_AES_128_CBC_SHA TLS_RSA_WITH_AES_256_CBC_SHA TLS_RSA_WITH_AES_128_CBC_SHA256 TLS_RSA_WITH_AES_256_CBC_SHA256 TLS_ECDHE_RSA_WITH_3DES_EDE_CBC_SHA TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384
I can get this setup to pass the scanner, gets an A- on SSL Labs, but cuts out support for many safari versions… ECDHE-ECDSA-AES256-GCM-SHA384:!AES256-SHA256:!AES128-SHA256:!AES256-SHA:!AES128-SHA:ECDHE:AES:AES-GCM:3DES:!MD5:!EXPORT:!DES:!EDH:!SSLv3:!RC4:!ADH:!TLSv1:!TLSv1_1:!3DES:!ECDHE+AES:RSA+AES This doesn’t pass the PCI scan but supports Safari… !LOW:!SSLv3:!MD5:!RC4-SHA:!EXPORT:DHE+AES:DHE+3DES:RSA+AES:RSA+3DES:ECDHE+AES:ECDHE-RSA-DES-CBC3-SHA
Can you retry with !CBC option? I’ve updated my original answer with the new string.
Would so love for that to work. We are on 11.5.3 and I get this: Invalid keyword ‘cbc’ in ciphers list for profile
Sorry for inconvinience, Ill check into it tomorrow. Hope you’re not in a rush ![]()
ALL AES ciphers are utilizing Cipher Block Chaining (CBC) even that “CBC” is not present in the actual name of the cipher suite. So to really exclude CBC you want to add !AES to your string. In my understanding the only PCI 3.1 compliant cipher are AES-GCM and TLS 1.3 However, it’s not 100% clear if those are PCI 3.1 of 4.0 compliance requirements.
Good morning,
I’ve read that CBC in combination with TLS1.2 is OK to use in case of PCI DSS 3.1 which will be enforced June 2016. Furthermore, our apps that process Visa and Mastercard payments were PCI-passed just this year with the same string I gave you initially. Without any changes, this will also pass the PCI DSS audit in June 2016. Can you specify which PCI version your scanner is using as the basis? I think youre too much ahead of the time, and those rules are probably not yet enforced at this point. Please clarify if you believe I’m not correct on that.
Nevertheless, to meet the requirements of your scanner, I’ve come to this string. Give it a try ![]()
tmm --clientciphers 'ALL:!EXPORT:!RC4:!DES:!ADH:!EDH:!SSLv3:!TLSv1:!SHA1'
ID SUITE BITS PROT METHOD CIPHER MAC KEYX
0: 49200 ECDHE-RSA-AES256-GCM-SHA384 256 TLS1.2 Native AES-GCM SHA384 ECDHE_RSA
1: 49196 ECDHE-ECDSA-AES256-GCM-SHA384 256 TLS1.2 Native AES-GCM SHA384 ECDHE_ECDSA
2: 49192 ECDHE-RSA-AES256-SHA384 256 TLS1.2 Native AES SHA384 ECDHE_RSA
3: 49188 ECDHE-ECDSA-AES256-SHA384 256 TLS1.2 Native AES SHA384 ECDHE_ECDSA
4: 163 DHE-DSS-AES256-GCM-SHA384 256 TLS1.2 Native AES-GCM SHA384 DHE/DSS
5: 106 DHE-DSS-AES256-SHA256 256 TLS1.2 Native AES SHA256 DHE/DSS
6: 49202 ECDH-RSA-AES256-GCM-SHA384 256 TLS1.2 Native AES-GCM SHA384 ECDH_RSA
7: 49198 ECDH-ECDSA-AES256-GCM-SHA384 256 TLS1.2 Native AES-GCM SHA384 ECDH_ECDSA
8: 49194 ECDH-RSA-AES256-SHA384 256 TLS1.2 Native AES SHA384 ECDH_RSA
9: 49190 ECDH-ECDSA-AES256-SHA384 256 TLS1.2 Native AES SHA384 ECDH_ECDSA
10: 157 AES256-GCM-SHA384 256 TLS1.2 Native AES-GCM SHA384 RSA
11: 61 AES256-SHA256 256 TLS1.2 Native AES SHA256 RSA
12: 49199 ECDHE-RSA-AES128-GCM-SHA256 128 TLS1.2 Native AES-GCM SHA256 ECDHE_RSA
13: 49195 ECDHE-ECDSA-AES128-GCM-SHA256 128 TLS1.2 Native AES-GCM SHA256 ECDHE_ECDSA
14: 49191 ECDHE-RSA-AES128-SHA256 128 TLS1.2 Native AES SHA256 ECDHE_RSA
15: 49187 ECDHE-ECDSA-AES128-SHA256 128 TLS1.2 Native AES SHA256 ECDHE_ECDSA
16: 162 DHE-DSS-AES128-GCM-SHA256 128 TLS1.2 Native AES-GCM SHA256 DHE/DSS
17: 64 DHE-DSS-AES128-SHA256 128 TLS1.2 Native AES SHA256 DHE/DSS
18: 49201 ECDH-RSA-AES128-GCM-SHA256 128 TLS1.2 Native AES-GCM SHA256 ECDH_RSA
19: 49197 ECDH-ECDSA-AES128-GCM-SHA256 128 TLS1.2 Native AES-GCM SHA256 ECDH_ECDSA
20: 49193 ECDH-RSA-AES128-SHA256 128 TLS1.2 Native AES SHA256 ECDH_RSA
21: 49189 ECDH-ECDSA-AES128-SHA256 128 TLS1.2 Native AES SHA256 ECDH_ECDSA
22: 156 AES128-GCM-SHA256 128 TLS1.2 Native AES-GCM SHA256 RSA
23: 60 AES128-SHA256 128 TLS1.2 Native AES SHA256 RSA
Good morning,
I will try this today! Thank you!!
It appears my hosted scanner (Rapid 7) is incorrectly listing these as insecure: TLS 1.2 ciphers: TLS_RSA_WITH_AES_128_CBC_SHA256 TLS_RSA_WITH_AES_256_CBC_SHA256 TLS_RSA_WITH_AES_128_GCM_SHA256 TLS_RSA_WITH_AES_256_GCM_SHA384 TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 I am going to put in an exception and we should be good! Thanks for your help!
