payload load based load balance and OSPF
Hello,
i wrote irule and it loadbalance clients to servers, it looks paylod in packets. it works without problem
i attached the customer topology, i showed bigip on topology
here is my requirements ;
all traffic will pass over bigip but i will use iRule for some traffics (i will look payload)
question;
which configuration type i need use on bigip
L2? or L3? vlangroup?
What can i do for OSPF, i dont want change customer ospf topology
the other thing
sometimes servers behind on ibmmainframe1 and some times behind ibm mainframe2
how can i deploy redundant bigip in this topology
note: does anybody deployed bigip with ibm mainframe?
regards
Zafer Berber
Do you have the routing module on your LTM pair? I’d recommend that over vlan groups in a redundant configuration. Yes, it’s possible, but I’d shy away from that.
