i tried to add %2e in the matches_regex but didn’t work, not sure if i added it at the right place, not very familiar with iRules… Anyone has an idea how to block this ?
f there isn’t a ? in the URI to delimit the path from the query string, then you should use HTTP::path or HTTP::uri--not HTTP::query.
Trying to do full URI validation in an iRule is going to be a losing battle in my mind as there are a lot of different encoding methods and path traversal methods. If you want full validation including URL normalization I suggest considering a web app firewall and/or adding more validation to the application.
As a limited measure you could start with something like this:
Fully decode the URI from:
http://devcentral.f5.com/wiki/iRules.FullyDecodeURI.ashx
set tmpUri [HTTP::uri]
set uri [URI::decode $tmpUri]
repeat decoding until the decoded version equals the previous value.
while { $uri ne $tmpUri } {
set tmpUri $uri
Check if the decoded URI has two consecutive dots
if {[string match {*..*} $uri]}{
reject
