Patching from 11.6.0 HF5 to 11.6.0 HF8 - Missing data and DNS (Globe) ICON
All,
After patching Hyperviosr and Guests from HF5 to HF8 the “DNS” icon menu was removed within each Guest instance and within the Hypervisor the LACP configuration was removed off of the trunks.
Any thoughts of why the above items would be removed after applying the patch?
~c
Hello,
Have you checked the license after the upgrade?
Also I remember there was a bug in the viprion systems which removes LACP when the blade reboots.
I would suggest to raise this issue with f5 support.
-Jinshu
Until September 2016, All licenses included DNS-Lite feature.
when you reactivate license, this feature is now not included anymore. this is not an upgrade issue but a change of licensing from F5 after reactivation.
