PATCH IRule REST API in transaction not executed
Hello,
When I do a PATCH request to edit an IRule in an Transaction then the change is not executed. When I do a PATCH request without a transaction the change is executed. I do the change together with an Persistence change. Both changes are in the same transaction, the persistence change is executed the IRule is unchanged.The Transaction validate and transaction commit gives both a HTTP 200 result.
Do I miss something or is this a bug in the BIG-IP REST API interface in cobination with F5 Transactions?
URL: mgmt/tm/ltm/rule/~Common~irule_persist_universal_example.test.nl-any-443
JSON payload:
{\"apiAnonymous\":\"when HTTP_REQUEST {\\n
   if { [HTTP::cookie exists \\\"JSESSIONID\\\"] } {\\n
          persist uie [HTTP::cookie \\\"JSESSIONID\\\"] 9292\\n
   }\\n
Try this:
!/bin/bash
USERPASS='admin:admin'
 create a transaction and return the transaction ID
transid=`curl -sk -u $USERPASS -H 'Accept: application/json' -H 'Content-Type: application/json' https://localhost/mgmt/tm/transaction -d '{}' |awk -F"," '{ print $1 }' |awk -F":" '{ print $2 }'`
 modify the iRule
curl -sk -u $USERPASS -H "X-F5-REST-Coordination-Id: $transid" -H "Accept: application/json" -H "Content-Type: application/json" -X PATCH https://localhost/mgmt/tm/ltm/rule/~Common~test1-rule -d@irule.txt
 modify persistence
curl -sk -u $USERPASS -H "X-F5-REST-Coordination-Id: $transid" -H "Accept: application/json" -H 'Content-Type: application/json' -X PATCH -d '{"persist":[{"name":"cookie"}]}' https://localhost/mgmt/tm/ltm/virtual/webserver-vip
 commit the transaction
curl -sk -u $USERPASS -H "Accept: application/json" -H "Content-Type: application/json" -X PUT https://localhost/mgmt/tm/transaction/$transid -d '{ "state":"VALIDATING" }'
where irule.txt is your iRule payload.
"apiAnonymous":" this is a test\n
when HTTP_REQUEST {\n
  log local0. \"Hello World\"\n
F5 dropped the ball on this one..it’s a 12.X bug; works on 13.X code.
