Past power alarm is showing up in dashboard
Hello all,
We are having viprion 2400 platform with 11.5.3 and hf7. Whenever we open dashboard utility for monitoring there is a power alarm showing,. The date it was showing is old so
i doubt it was false alarm, to cross check i checked in CLI through - tmsh show sys hardware and both power supply and fan status is showing ok. I want to know how i can clear this past dashboard alarm in vipiron. the chassis is having two blades populated. which solution should i follow- 1. 404 Page not found | BIG-IP Documentation 2. 404 Page not found | BIG-IP Documentation
or any other idea…!
Chassis Fan Status Index Status Low Limit(rpm) Fan Speed(rpm) 1 up 750 2911 2 up 750 2902 3 up 750 2917 4 up 750 2902
Chassis Information Maximum MAC Count 2 Registration Key XXXXXXXXXXXX
Chassis Power Supply Status Index Status Current 1 up AC 2 up AC
CPU Status Slot Index Temp(degC) Fan Speed(rpm) 1 1 42 4674 2 1 43 4642
I would start with 1 and see if that works out.
if you are uncertain and have a support contract then just contact them, it’s what they are for.
