Hello community,
Need some help here.
Our MSSP observed and notified us of successful password spray behavior from one of the self-IPs on our BIG-IP resulting in the lockout of a significant number of accounts. Where’s the best place to start gathering information about this incident on the BIG-IP?
@JRahm
Regards,
Some good initial actions probably are:
- Determine the protocol used for the auth attempts sourced from your IP. Was it HTTP? Kerberos? RADIUS?
- The most likely source for the traffic is someone accessing the internet through your BIG-IP. Does your config offer NATting for outbound arbitrary connections? If so, what is your acceptable use policies and auditing/logging policies for this service?
- If your config does NOT offer NATing over the network, it is possible that you have an unauthorized user. The self-ips can be used to source connections from the control plane, depending on how the BIG-IP’s routing is set up. Review this solution article:
myF5
@Olayinka-F5LB - Please select Mark As Solution if this is resolved. That helps others locate the good stuff faster.
Thanks!
