Passive HTTP capture
We have a requirement to capture all the HTTP request and response passively without impacting live systems for analysis. I looked at Pion, tealeaf for instance but wondering if F5 provides any such solution. If not then could you recommend some other lite weight products?
ExtraHop, but then again I’m quite biased :slight_smile:
No matter which way you go, you’ll want to use taps or SPANs as a low-impact way to keep track of things.
--Matt
Hi Manc,
Extrahop would be a very capable option for this. Else, if you want more basic cloning of HTTP requests, you could use a High Speed Logging iRule or request logging profile:
Manual Chapter: Using the Request Logging Profile
Log Tcp And Http Request Response Info Remotely
High Speed Logging should be a very low overhead way to syslog off the HTTP requests to a remote host.
Aaron
