PASS TRAFFIC BETWEEN ROUTE DOMAIN
Hello
I want to pass traffic between one route domain internal to RD external, because I need to pass traffic of server internal to service on internet, the internal traffic didn’t pass to network DMZ, the F5 has network internal and DMZ, in with route domain, with properties “strict isolation”. Help me
You have to disabled strict isolation:
the BIG-IP system allows traffic forwarding from that route domain to any route domain on the system, without the need to define a parent-child relationship between route domains. Note that in this case, for successful forwarding, you must disable the strict isolation feature on both the forwarding route domain and the target route domain (that is, the route domain to which the traffic is being forwarded).
the problem is that your RD is no longer isolated and at the base it is the goal…
Regards
