Hi, I am implementing route domains in our environment on 2 x 1600 ltm in an active/standby pair. I am planning to use different route domains in the same “common” partition instead of creating different partition for each route domain. Reason being as this is not a multi-tenancy setup and i do not need to provide different access roles, priviliges to different partitions.
Can anyone please let me know if there are any issues for this type of design? Will I face any issues in the long run in terms of failover?
Have you had a read of
search - The default route domain for partition Common
search - Additional route domain considerations
as long as you plan out your traffic profile/considerarions correctly, I would assume not.
Hi sandevsingh ,
Did you implement this as you stated in your post ??
Any issues you faced .
I am planning for same type of setup.
Regards
Hi Struggler, we did not go with this design. In my opinion, only use route domains/RD if you have overlapping ip addresses. (In case of multi-tenancy setup). When I was trying to implement this, I found out that you can have only 1 RD per partition. There is a one-to-one relationship between a RD and a partition. So we decided to skip this altogether, just to make things simple.
Ok Thanks for your feedback.. i am planning to create 3 route domains in common partition . I will have single HA vlan between two LTM pair in default route-domain 0. I will create three traffic-groups and bind those with respective route-domains . Regards
It may be the version issue . I have seen posts here in Devcentral where people created multiple route domains in common partition
Following is the note in the documentation:
If you want to segment traffic into multiple route domains, you can create additional route domains in partition Common and then segment application traffic among those route domains. 404 Page not found | BIG-IP Documentation
