I have have a URI that is www.governor/sir/vote and www.governor/vote. I need to send www.governor/vote to l7-ete-amsi pool. For www.governor/sir/vote, I need to strip out /sir/ and have the URI go to L7-ETE-AMSI-REDIRECT.
Thanks, this is a lot closer. The default pool works now. However, I’m not getting the /sir/ to be replaced with /. Any ideas? I’ve checked the case on the url and it’s lower case.
Do you see the URI being updated in the request made to the server? The value for HTTP::uri is cached in the same event (and same priority) so you wouldn’t see it log statements in the HTTP_REQUEST event.
Else, can you try with some debug logging:
log local0. "[IP::client_addr]:[TCP::client_port]: Original URI: [HTTP::uri]"
switch -glob [HTTP::path] {
"/sir/*" {
HTTP::uri [string map {"/sir/" "/"} [HTTP::uri]]
pool L7-ETE-AMSI-REDIRECT
default {
pool l7-ETE-AMSI
when HTTP_REQUEST priority 501 {
log local0. "[IP::client_addr]:[TCP::client_port]: Current URI: [HTTP::uri]"
