We require a special iRule to parse the cookie for company codes and direct them to a specific pool. For example each client will have an unencrypted cookie that will contain a unique company code ie. (A1, B1, and C1). We would like to direct clients to a specific pool based on that company code.
A1 goes to pool POOL1
B1 goes to pool POOL2
C1 goes to pool POOL3
and so forth…
Is there something we could craft that would allow this logic to work properly? Any help is greatly appreciated. Thx!
A cookie is generally a key-value pair, so is the A1, B1, C1 a key or a value?
For example, if it’s a value (assuming the cookie name is “COMPANY_CODE”):
switch { [HTTP::cookie "COMPANY_CODE"] } {
"A1" { pool POOL1 }
"B1" { pool POOL2 }
"C1" { pool POOL3 }
default { reject }
Of course this doesn’t work if the cookie is passed AFTER the initial request. Do you have an out-of-band mechanism to distribute the cookies, or will the user connection initially without the cookie and hope to get one at some point?
So after digging into this more. Looks like the initial client request doesn’t receive the cookie until successful login. Once the successful login the cookie is issued corresponding to a user to a unique company code. After testing this irule it seems to be inconsistent and not working properly, is it because of the cookie not being in the initial request? Is there a way to get this to work under these circumstances?
switch [HTTP::cookie “UserInfo”] {
“COMPANYID=A1” {
log local0. " matched COMPANYID=A1 in cookie UserInfo "
pool DEV-POOL1-80 }
“COMPANYID=B1” {
log local0. " matched COMPANYID=B1 in cookie UserInfo "
pool DEV-POOL2-80 }
“COMPANYID=C1” {
log local0. " matched COMPANYID=C1 in cookie UserInfo "
