Problem this snippet solves:
Provides a packer template that can be used to build a Vagrant “box” from a BIG-IP VE
Code :
"variables": {
"sudo_url": "http://repo.centos.org/files/sudo-1.8.16-1.el5.x86_64.rpm",
"sudo_rpm": "sudo-1.8.16-1.el5.x86_64.rpm"
"builders": [
"type": "virtualbox-ovf",
"source_path": "BIGIP-11.6.0.0.0.401.LTM_1SLOT-ide.ova",
"ssh_username": "root",
"ssh_password": "default",
"ssh_wait_timeout": "30000s",
"headless": "false",
"shutdown_command": "shutdown -h now",
"import_flags": ["--eula", "accept"],
"guest_additions_mode": "disable",
"vm_name": "BIGIP-11.6.0.0.0.401.LTM_1SLOT-ide",
"vboxmanage": [
["modifyvm","{{.Name}}","--memory","4096"],
["modifyvm","{{.Name}}","--cpus","2"],
["modifyvm","{{.Name}}","--nic1","NAT"]
"post-processors": [
"type": "vagrant",
"compression_level": 1,
"keep_input_artifact": true,
"output": "BIGIP-11.6.0.0.0.401.LTM_1SLOT-ide.box"
"provisioners": [
"type": "shell",
"inline": [
"mount -o remount,rw /dev/mapper/vg--db--hda-set.1._usr /usr",
"curl -o /tmp/{{ user `sudo_rpm` }} {{ user `sudo_url` }}",
"rpm -Uvh /tmp/{{ user `sudo_rpm` }}",
"tmsh create auth user vagrant password vagrant partition-access add { all-partitions { role admin } } shell bash",
"echo 'vagrant ALL=(ALL) NOPASSWD:ALL' > /etc/sudoers.d/vagrant",
"mkdir -p /home/vagrant/.ssh",
"chmod 0700 /home/vagrant/.ssh",
"curl --insecure -L -o /home/vagrant/.ssh/authorized_keys https://raw.github.com/mitchellh/vagrant/master/keys/vagrant.pub",
"chmod 0600 /home/vagrant/.ssh/authorized_keys",
"chown -R vagrant /home/vagrant/.ssh",
"tmsh save sys config"
