OWA with external logon page and SSO select
Hi there,
I have been trying to setup OWA with a custom logon screen to allow the various flags to be set for Light, Public and Private, and then depending on the flags set to select the appropriate SSO settings. This logon page is hosted on the F5 using iFiles.
The initial VS deployment was done using the iApp template: f5.microsoft_exchange_2010_cas.2012_04_06 and we are using OWA, Outlook Anywhere, ActiveSync and Autodiscover and are running 11.1.0 HF3
This is working to a large extent but only if the user goes straight to the logon page (which is hosted on a different port).
User connects to https://mail.acme.com:8443/owa\_custom\_logon
User submits credentials which are posted to a fake URI on https://mail.acme.com/owa\_fake\_capture , an iRule is in place to capture the content and populates a number of variables:
The iRule is:
check for post request
set url 0
if {[HTTP::uri] starts_with “/owa_fake_capture” and [HTTP::method] eq “POST”}{
The above URI ???/??? should be true based on the iFiles LOGON.ASPX file POST contents
Ensure this is the case
set url 1
set my_content_length [HTTP::header “Content-Length”]
HTTP::collect $my_content_length
when HTTP_REQUEST_DATA {
Set the collected POST variables into keys in the LTM session table
if { $url ==1} {
table set key_owa_flags [findstr [HTTP::payload] flags 6 “&”] 0 indefinite
table set key_owa_trusted [findstr [HTTP::payload] trusted 8 “&”] 0 indefinite
table set key_owa_username [findstr [HTTP::payload] username 9 “&”] 0 indefinite
table set key_owa_password [findstr [HTTP::payload] password 9 “&”] 0 indefinite
HTTP::release
redirect is required as user landing uri was /owa_fake_capture
HTTP::redirect https://mail.acme.com/owa
APM kicks in and using the captured variables signs the user in and gets them into the appropriate SSO using WEBSSO::select depending on the flags set.
If a user was to go directly to https://mail.acme.com/owa APM would deny access as there is no logon page configured in the VPE.
Now what I was trying to do was to add an external logon page to the VPE, and modifying the external logon page to post to /my.policy, which would do the following:
User connects to https://mail.acme.com/
User is redirected to https://mail.acme.com/owa
APM kicks in and user is sent to external logon page on https://mail.acme.com:8443/owa\_custom\_logon, APM is expecting username and password to be posted to post_url https://mail.acme.com/my.policy (according to the documentation)
User submits credentials which are posted to https://mail.acme.com/my.policy , an iRule is in place to capture the additional content.
The iRule is:
set url 0
if {[HTTP::uri] starts_with “/my.policy” and [HTTP::method] eq “POST”}{
set url 1
if { $url ==1} {
HTTP::release
redirect is not required as users landing uri is /owa
However nothing else is captured by the F5 (I enabled logging at various stages in the iRule and it just returns with blank entries). Username and Password are captured but I suspect that is the workings of the javascript it inserts when redirecting the user to the external logon page and the fact that APM has started.
I realise I could setup a separate VS for OWA (https://owa.acme.com) capture the creds there and then redirect them to the APM enabled VS (https://mail.acme.com), but I would prefer to have everything under the one.
Has anyone else found a nice way around this?
