Hi all ,
I have configure APM for outlook anywhere & OWA and it is work fine both ,
the issue when I add in policy windows client check or antivirus check , rsa , i cant connect for anywhere only for OWA ,
is there any way to avoid the client check for anywhere only ,
You can add a check in the VPE to see if you are connections from a Microsoft client (outlook). If you are the don’t have the client checks on that branch.
Seth
You can use a VPE action of “Client for MS Exchange” which is under “Endpoint Security (Server-Side)” to determine the client type connecting. If they are connecting from an MS Exchange client then you do the normal single factor auth and if they are in the “fallback” (OWA) then you present a logon page, etc. This should be how the iApp creates the APM policy.
