I installed my shiny new GTM/LTM last Sunday and things looked pretty good until yesterday afternoon.
I noticed on the Performance->Active Connections graph that there was a constant upward trend over the week. Yesterday it reached about 180K requests and consequently (I suspect this way why) the system rebooted itself - not cool in the middle of the work day.
I have defined a Local Traffic Pool with my two edge routers. I have set this as the “Default IPv4” destination under Network->Routes. This may be of no consequence but I defined separate VLANs for the edge routers - since they are different subnets this seemed logical.
Also per the docs I defined a wildcard virtual server (0.0.0.0:0) and assigned it to my internal VLAN. I’m not sure what this is doing for me as it has no pool or rule attached to it but I’m almost to the point of sprinkling chicken blood on it while chanting Yellow Submarine lyrics backwards.
Also, could I be looking at this from the wrong direction? Is it possibly my inbound traffic that is driving up the connection count? My site isn’t one that people would stay connected to for more than an hour at the absolute tops.
BTW, the route dictates where the LTM sends the traffic, the virtual forwarder 0.0.0.0/0 is required to allow the traffic to flow. In version 9, the F5 is a default-deny box, so any desired flows need permission, even if routes are present.
Is there a corresponding upward trend in memory consumption along with the increasing connection count? What was the TMM memory usage at when the restart happened?
Out of curiosity, on the wildcard VIP’s fastL4 profile, what is the timeout set to? I hope not indefinite. If you look at the ‘b conn all show all’ output, what are the majority of the connections you see? What are the idle count and idle timeout values for the connections?
In this example, the idle count is 11 seconds and the timeout is 300:
VIRTUAL 1.2.3.241:ssh <-> NODE 1.2.3.246.241:ssh LOCAL
CLIENTSIDE 2.1.45.39:squid <-> 2.81.246.241:ssh
(pkts,bits) in = (55, 58928), out = (47, 53584)
SERVERSIDE 2.1.45.39:squid <-> 2.81.246.241:ssh
(pkts,bits) in = (47, 53584), out = (55, 58928)
PROTOCOL tcp UNIT 0 IDLE 11 (300) LASTHOP 4094 00:fc:0f:2c:bc:00
