OK, so just want to share my design to see if there is any ways I could improve the design.
Environment: F5 BIG-IP LTM with three ISP.
Goal: Create Static NATs on LTM for the ISP which do not need to be Load-Balanced (Outbound).
LTM Design:
1 VServer Outbound_TCP
-- Address: 0.0.0.0 / 0.0.0.0 port 0
-- Type: Standard
-- Protocol: TCP
-- VLAN on Internal Network
-- SNAT: none
-- Default Pool: default_gateways (all three ISP gateways)
-- Persistence: Outbound (src_addr with 3600 sec and all buttons checked)
-- I-rule: Outbound_irule
2 Vserver Outbound_UDP
-- Type: Standard
-- Protocol: UDP
-- SNAT: none
3 Vserver Outbound_FTP
-- Address: 0.0.0.0 / 0.0.0.0 port 21
-- Type: Standard
-- Protocol: TCP
-- profile: ftp
-- SNAT: none
4 Vserver Outbound_General
-- Type: Forwarding IP
-- Protocol: All
-- SNAT: none
-- Default Pool: None - This will use the BIG-IP Default Routes (same pool as above)
-- Persistence: None for Forwarding IP
5 Pool: default_gateways
-- Monitor: gateway_icmp
-- Monitor: gateway_icmp - next hop
6 BIG-IP Gateway
-- Default Gateway: default_gateways pool
-- Static routes: one server route through each ISP for Monitoring
-- Load-Balance: Predictive Member - We are still playing with this
7 NATs
-- Create a NAT for servers behind the LTM - make sure everyone knows that if that ISP goes down that those servers will also be unavailable on the Internet
8 Datagroups (under I-Rules)
-- Add servers IP Address to the ISP datagroup
9 I-Rule
aaa.aaa.aaa.agw and default_gateway_isp_a is the default gateway for ISP A
bbb.bbb.bbb.bgw and default_gateway_isp_b is the default gateway for ISP B
ccc.ccc.ccc.cgw and default_gateway_isp_c is the default gateway for ISP C
aaa.aaa.aaa.nat and snatpool snat_isp_a is the SNAT Pool for ISP A
bbb.bbb.bbb.nat and snatpool snat_isp_b is the SNAT Pool for ISP B
ccc.ccc.ccc.nat and snatpool snat_isp_c is the SNAT Pool for ISP C
network_force_pool_isp_a is the datagroup for IP Address which needs to be route through ISP A only because they have their own Static NAT or SNAT
network_force_pool_isp_b is the datagroup for IP Address which needs to be route through ISP B only because they have their own Static NAT or SNAT
network_force_pool_isp_c is the datagroup for IP Address which needs to be route through ISP C only because they have their own Static NAT or SNAT
when LB_SELECTED {
if { [matchclass [IP::client_addr] equals $::network_force_pool_isp_a] }
log local0. “no SNAT ISP A for IP [IP::client_addr]”
forward
} elseif { [matchclass [IP::client_addr] equals $::network_force_pool_isp_b] }
log local0. “no SNAT ISP B for IP [IP::client_addr]”
forward
} elseif { [matchclass [IP::client_addr] equals $::network_force_pool_isp_c] }
log local0. “no SNAT ISP C for IP [IP::client_addr]”
forward
} elseif { [LB::server addr] eq “aaa.aaa.aaa.agw” }
log local0. “SNAT [IP::client_addr] natt’ed to aaa.aaa.aaa.nat, via ISP A”
snatpool snat_isp_a
} elseif { [LB::server addr] eq “bbb.bbb.bbb.bgw” }
log local0. “SNAT [IP::client_addr] natt’ed to bbb.bbb.bbb.nat, via ISP B”
snatpool snat_isp_b
} elseif { [LB::server addr] eq “ccc.ccc.ccc.cgw” }
log local0. “SNAT [IP::client_addr] natt’ed to ccc.ccc.ccc.nat, via ISP C”
snatpool snat_isp_c
when CLIENT_ACCEPTED {
log local0. “Force Pool ISP A for IP [IP::client_addr]”
pool default_gateway_isp_a
log local0. “Force Pool ISP B for IP [IP::client_addr]”
pool default_gateway_isp_b
log local0. “Force Pool ISP C for IP [IP::client_addr]”
pool default_gateway_isp_c
