Here are two tcpdumps of the same connection.
The connection is from host 130.68.1.212 - which is behind our LTM, being SNATed as 130.68.2.31 to “the world” - to 208.185.32.185 on port 80 (our host out on “the internet”).
The first tcpdump is capturing traffic on our vlan “subnet_2” which is associated with all 130.68.2.0 addresses.
The second tcpdump is capturing traffic on our vlan “public_inet” which is associated with all 130.68.1.0 addresses.
from vlan “subnet_2” (130.68.2.0)
reading from file tcpdump_12316.dmp, link-type EN10MB (Ethernet)
10:34:10.739185 IP (tos 0x0, ttl 51, id 0, offset 0, flags [DF], proto TCP (6), length 52) 208.185.32.185.80 > 130.68.2.31.64384: S, cksum 0x1576 (correct), 246177326:246177326(0) ack 3791885143 win 1460
10:34:10.739212 IP (tos 0x0, ttl 255, id 7382, offset 0, flags [DF], proto TCP (6), length 40) 130.68.2.31.64384 > 208.185.32.185.80: R, cksum 0x5bf3 (correct), 1:1(0) ack 1 win 0
10:34:12.500509 IP (tos 0x0, ttl 51, id 0, offset 0, flags [DF], proto TCP (6), length 52) 208.185.32.185.80 > 130.68.2.31.64396: S, cksum 0xac86 (correct), 259263702:259263702(0) ack 253042618 win 1460
10:34:12.500533 IP (tos 0x0, ttl 255, id 11571, offset 0, flags [DF], proto TCP (6), length 40) 130.68.2.31.64396 > 208.185.32.185.80: R, cksum 0xf303 (correct), 1:1(0) ack 1 win 0
10:34:14.107204 IP (tos 0x0, ttl 51, id 0, offset 0, flags [DF], proto TCP (6), length 52) 208.185.32.185.80 > 130.68.2.31.64384: S, cksum 0xb1c5 (correct), 249545131:249545131(0) ack 3791885143 win 1460
10:34:14.107228 IP (tos 0x0, ttl 255, id 15250, offset 0, flags [DF], proto TCP (6), length 40) 130.68.2.31.64384 > 208.185.32.185.80: R, cksum 0xf842 (correct), 1:1(0) ack 1 win 0
10:34:14.115202 IP (tos 0xc0, ttl 242, id 7741, offset 0, flags [none], proto ICMP (1), length 68) 208.185.32.185 > 130.68.2.31: ICMP host 208.185.32.185 unreachable - admin prohibited, length 48
IP (tos 0x0, ttl 244, id 15250, offset 0, flags [DF], proto TCP (6), length 40) 130.68.2.31.64384 > 208.185.32.185.80: R, cksum 0x8251 (correct), 1582045095:1582045095(0) ack 1 win 0
10:34:15.867192 IP (tos 0x0, ttl 51, id 0, offset 0, flags [DF], proto TCP (6), length 52) 208.185.32.185.80 > 130.68.2.31.64396: S, cksum 0x4ea1 (correct), 262630024:262630024(0) ack 253042618 win 1460
10:34:15.867216 IP (tos 0x0, ttl 255, id 18971, offset 0, flags [DF], proto TCP (6), length 40) 130.68.2.31.64396 > 208.185.32.185.80: R, cksum 0x951e (correct), 1:1(0) ack 1 win 0
from vlan “public_inet” (130.68.1.0)
reading from file tcpdump_12362.dmp, link-type EN10MB (Ethernet)
10:38:52.761141 IP (tos 0x0, ttl 64, id 2785, offset 0, flags [DF], proto TCP (6), length 52) 130.68.1.212.64729 > 208.185.32.185.80: S, cksum 0x20b3 (correct), 1826467050:1826467050(0) win 49640
10:38:52.761186 IP (tos 0x0, ttl 63, id 2785, offset 0, flags [DF], proto TCP (6), length 52) 130.68.2.31.64729 > 208.185.32.185.80: S, cksum 0x2068 (correct), 1826467050:1826467050(0) win 49640
10:38:53.013422 IP (tos 0x0, ttl 64, id 33625, offset 0, flags [DF], proto TCP (6), length 52) 130.68.1.216.54519 > 208.185.32.185.80: S, cksum 0x61a0 (correct), 3742572965:3742572965(0) win 49640
10:38:53.013439 IP (tos 0x0, ttl 63, id 33625, offset 0, flags [DF], proto TCP (6), length 52) 130.68.2.31.54519 > 208.185.32.185.80: S, cksum 0x6159 (correct), 3742572965:3742572965(0) win 49640
10:38:56.130563 IP (tos 0x0, ttl 64, id 2786, offset 0, flags [DF], proto TCP (6), length 52) 130.68.1.212.64729 > 208.185.32.185.80: S, cksum 0x20b3 (correct), 1826467050:1826467050(0) win 49640
10:38:56.130580 IP (tos 0x0, ttl 63, id 2786, offset 0, flags [DF], proto TCP (6), length 52) 130.68.2.31.64729 > 208.185.32.185.80: S, cksum 0x2068 (correct), 1826467050:1826467050(0) win 49640
10:38:59.772311 IP (tos 0x0, ttl 64, id 33626, offset 0, flags [DF], proto TCP (6), length 52) 130.68.1.216.54519 > 208.185.32.185.80: S, cksum 0x61a0 (correct), 3742572965:3742572965(0) win 49640
10:38:59.772329 IP (tos 0x0, ttl 63, id 33626, offset 0, flags [DF], proto TCP (6), length 52) 130.68.2.31.54519 > 208.185.32.185.80: S, cksum 0x6159 (correct), 3742572965:3742572965(0) win 49640
10:39:01.016667 IP (tos 0x0, ttl 255, id 23769, offset 0, flags [DF], proto TCP (6), length 40) 208.185.32.185.80 > 130.68.1.212.64729: R, cksum 0x2353 (correct), 0:0(0) ack 1826467051 win 0
10:39:07.116736 IP (tos 0x0, ttl 255, id 32785, offset 0, flags [DF], proto TCP (6), length 40) 208.185.32.185.80 > 130.68.1.216.54519: R, cksum 0x6440 (correct), 0:0(0) ack 3742572966 win 0
