Order of precedence for virtual server when using source address
I am creating a “catch all” virtual server (destination:0.0.0.0/0).
VIP_Default source: 0.0.0.0/0, destination 0.0.0.0/0
But for a single subnet, I will have another VS serve this traffic:
VIP_Special source: 198.19.0.128/25, destination: 0.0.0.0/0
But it does not seem like a more specific source address have anything to say when it comes to order of precedence when selecting VS. Incoming traffic from source 198.19.0.128/25 will hit VIP_Default, and not the more specific vs, VIP_Special.
In desperate attempt to just solve this, I attempted to create two more specific destination routes by splitting 0.0.0.0/0 into two equal parts:
VIP_Special_A, source: 198.19.0.128/25, destination: 0.0.0.0/1
and
VIP_Special_B, source: 198.19.0.128/25, destination: 128.0.0.0/1
But I here I get the error message “Invalid host/ip” for 0.0.0.0/1 in the GUI. The CIDR address 128.0.0.0/1 however is ok.
I believe both my attempts should be working fine. Am I doing something wrong, or have I hit a limitation/bug in the F5 software?
My version is 12.1.1 HF1
Recommend to delete all client-side (cs) connections on VIP_Default.
The closer-match VIP_Special will get the special subnet connections (works as intended in 12.1.1). However, as with any F5 change you must acknowledge that previously established sessions are not aware of your configuration changes.
Other things that can be wrong: VLANs (on which the Virtual Server is listening), the source IP of the ‘special subnet’ really does not match (perhaps a SNAT takes place?). If you need further help, please paste the full configuration of both Virtual Servers (
tmsh list ltm virtual VSname
If I change the VS_CP_Inet_Forward / VIP_SPECIAL to only listen for port 443, it will start consuming traffic immediately.
If it was a problem with the source address, the VS_CP_Inet_Forward should not start accepting traffic because I gave it precedence by setting a more specific port.
This is the VS that should receive traffic from the 198.19.0.128/25 subnet.
ltm virtual VS_CP_Inet_Forward {
    destination 0.0.0.0%65000:any
    ip-protocol tcp
    mask any
    profiles {
        tcp-wan-optimized { }
    rules {
        irule_cp_cluster_forward
    source 198.19.0.128%65000/25
    source-address-translation {
        type automap
    translate-address enabled
    translate-port enabled
    vlans {
        iApp_webproxy-70-0-D
    vlans-enabled
    vs-index 21
And this is the more generic VS
`ltm virtual iApp_webproxy.app/iApp_webproxy-70-D-0-t-4 {
    app-service /Common/iApp_webproxy.app/iApp_webproxy
    description "cp_cluster (1476971594)"
    ip-protocol tcp
    mask any
    profiles {
        iApp_webproxy.app/iApp_webproxy-tcp-lan {
            context clientside
        iApp_webproxy.app/iApp_webproxy-tcp-wan {
            context serverside
        iApp_webproxy.app/iApp_webproxy-xssl {
            context serverside
    rules {
        iApp_webproxy.app/iApp_webproxy-ilD
    source 0.0.0.0%65000/0
    translate-address disabled
    translate-port disabled
    vlans {
    vlans-enabled
    vs-index 16
    ip-protocol tcp
    mask any
    profiles {
    rules {
        type automap
    vlans {
    vlans-enabled
    vs-index 21
    ip-protocol tcp
    mask any
    profiles {
            context clientside
            context serverside
            context serverside
    rules {
    vlans {
    vlans-enabled
    vs-index 16
