We have 10 iRules in specific order . Will they execute in same order ?
Hi Vasu,
Yes they should execute in the order you had placed each iRule. Atleast that is what mine does. ![]()
Bhattman
Here are a few related posts on iRule priority:
iRules 101 - 11 - Events
http://devcentral.f5.com/Default.aspx?tabid=63&articleType=ArticleView&articleId=165
Irule Preference
http://devcentral.f5.com/Default.aspx?tabid=53&forumid=5&tpage=1&view=topic&postid=57335
when EVENT “chaining” and variable scope
http://devcentral.f5.com/Default.aspx?tabid=53&forumid=5&tpage=1&view=topic&postid=60810
Aaron
In https://devcentral.f5.com/articles/stacking-irules-a-modular-approach.Uyf0upjYN1U , it is stated:
“iRules are executed in the order they are applied to the virtual server (the order in which they appear in the GUI, the configuration file or in ‘bigpipe virtual show’ commands.)”
But “Local Traffic ›› Network Map” and “Local Traffic ›› Virtual Servers : Virtual Server List ›› my_vs” show a different (opposite) order (only 2 irules).
Any explanation for this?
I am on v10.2.4 HF7.
