I’m trying to access oracle forms using firepass ( i have configured the ERP portal in the Portal resource of firepass.
when i try to access the oracle forms i get the following error msg
Load:class oracle/apps/fns/formsClient/FormsLauncher.class not found
please advice,
thanks in advance.
rgds,
Ram
I am getting the same. Please assist.
try using application tunnel..
it worked for me..
Sriram
Use
Minimal Content-Rewriting Bypass
Patterns - /OA_HTML/*
HostL Your oracle server:8003
ccb
5
Hi SRS,
Could you please give an example of the syntax you used to get the application tunnel to work.
