Hi below is a rule being used together with geofilter and looking at the specific uri and then sending requests to different pools based on the Country, is there a more effective way todo the same thing with the switch command ?
Any suggestions for optimization appreciated.
when CLIENT_ACCEPTED {
if {([class match [whereis [IP::client_addr] country] eq Allowed_Country_Test] or [class match [IP::client_addr] eq allowed_ip])} {
set allowed 1 }
else { set allowed 0 }}
if { $allowed } {
if {[whereis [IP::client_addr] country ] eq “FI” and [HTTP::uri] contains “/compass/” } {
pool CompassFI_Test_http_pool
} elseif {[whereis [IP::client_addr] country ] eq “DK” and [HTTP::uri] contains “/compass/” } {
pool CompassDK_Test_http_pool
pool Compass_Test_http_pool
do whatever you want to indicate the block, e.g.
HTTP::respond 403 content “The country or IP is not allowed to access this site”
Here’s an example which minimized the repeated commands with an intermediate variable for the country code:
set cc [whereis [IP::client_addr] country]
if { [class match $cc eq Allowed_Country_Test] or [class match [IP::client_addr] eq allowed_ip] } {
set allowed 1
set allowed 0
if { $allowed } {
switch $cc {
"FI" -
"DK" {
if {[HTTP::uri] contains "/compass/" } {
pool Compass${cc}_Test_http_pool
default {
HTTP::respond 403 content "The country or IP is not allowed to access this site"
Hi Aaron it would seem that we have a problem with the application it needs the ports to be changed in the host header,and we use diiferent ports depending on the country.
Now i know the synatx for the port change:-
HTTP::header replace Host [string map {:80 :7775} [HTTP::host]] for Finland and then
HTTP::header replace Host [string map {:80 :7776} [HTTP::host]] for Denmark and then last
HTTP::header replace Host [string map {:80 :7777} [HTTP::host]] for the default pool
But iam not sure how to combine these statements in the optimised irule you helped me with.
Now i could probably do this i another irule but it would be much better to combine them.
