Optimize iRule for ASM
Dear all,
recently we are designed and activated an iRule to make several decisions:
- when there isn’t any member available in the production pool, the request is redirected to a sorry;
- in other case the request is redirected to ASM.
This second case is a little special because the web app is written using two diferent charsets, win-1252 and utf-8, that are used depending of the first level of uri path. For example:
- utf-8: http://server/PATH1/piemf.txt or http://server/PATH2/qwxsa.txt
- win-1252: anypath else
We are developed an iRule to do this:
__> SORRY_POOL
             ______   _______ /
    USER --->| vs |-->|iRule| --->HTTPClass_PROD_POOL_PATH1_PATH2-----> PROD_POOL
             ------   ------- \__>HTTPClass_PROD_POOL_PATH1_PATH2__/
                               \_>HTTPClass_PROD_POOL_REST________/
And this is the code:
   set debug "0"
   if { [active_members PROD_POOL] < 1 } {
     Pool selected in case of all production members are down
    if { $debug } { log local0. "select Sorry" }
     ASM must not work
    HTTP::class disable
     PoolSorry becomes traffic
    pool SORRY_POOL
     The variable gets the first level of path
    set URI_value [findstr [HTTP::uri] "/" 1 "/"]
    if { $debug } { log local0. "uri $URI_value" }
    switch $URI_value {
     PATH1 {
      if { $debug } { log local0. "PATH1" }
      HTTP::class enable
      HTTP::class select HTTPClass_PROD_POOL_PATH1_PATH2
     PATH2 {
      if { $debug } { log local0. "PATH2" }
      HTTP::class enable
     default {
      if { $debug } { log local0. "REST" }
      HTTP::class enable
      HTTP::class select HTTPClass_PROD_POOL_REST
This rule is applied in several VS.
Now all this configuration is applied and it works, but the performance of CPUs is very high (CPU0: 80%, CPU1: 100%, AVERAGE: 90%). The main overhead is being introduced by ASM (we can see in ASM CPU Graphs), but it is only a 40 % of CPU0.
We haven’t an exact value of CPU impact of this iRule, but we think that it could be optimized to reduce the resouces needed.
Does someone how could we do better the iRule to reduce CPU utilization??
Regards,
fermarloe
Hi Fernando,
Which ASM version are you running (b version)? And which platform are you running ASM on (b platform | head)?
I expect that the increased load is due to ASM--not the iRule. For 9.x, ASM processes (mainly bd and mysqld) run on CPU0 and TMM runs on CPU1. And iRules run within TMM. So if you’re seeing low CPU1 usage, it means the iRule is not the major concern. You might be able to optimize the iRule slightly with a switch statement and using getfield instead of findstr, but the existing version should be fine.
In 9.x, TMM doesn’t provide reporting to the Linux host on how many cycles its using. So top and ps will show TMM using 50% of both CPUs (and 100% of CPU1). The performance graphs in the GUI or tmstat from the CLI will show more accurate usage for TMM.
Which processes on CPU0 are using the majority of the CPU cycles? Is it bd, mysql or learning_manager.pl? If it’s bd or mysql, then there is cause for concern. learning_manager.pl is set to a lower CPU priority so it will give up cycles as standard priority processes require them.
How many HTTP requests per second did you have going through ASM or the unit in total while the BD CPU graph was showing ~60% load?
Aaron
BIG-IP Version is 9.4.7 330.35 and an HF2 and an engineering HF
b version
 Kernel:
 Linux 2.4.21-9.4.7.320.0smp
 Package:
 BIG-IP Version 9.4.7 330.35
 Hotfix HF2 Edition
 Hot fixes:
    CR100218
    CR124714
    CR125718
    CR125853
    CR126690
    CR132165
    CR132166
    CR132167
    CR132783
The results of command:
b platform | head
 PLATFORM INFORMATION --
 |     Marketing Name: BIG-IP 8400
 |     BIOS Rev: AMIBIOS(C)2003 American Megatrends, Inc.                                       8400V BIOS Version: OBJ-0099-01 Rev. V8400V170   Date:12/09/2005
 |     base MAC: 00:01:D7:69:85:40
 |     PVA Version: 10
 +-> SYSTEM INFO
 |     Type: D84
 |     Chassis   serial: bip237237s   Level 200 part: 200-0242-15 REV A
 |     Switch board   serial: PCA0116MW6ED   part: PCA-0116-05 REV A
 |     Host board   serial: FX070611O090051   part: MOB-0019-06 REV B
We don’t know exactly how many HTTP_requests/second. I attach a graph related with the traffic of the main web page…
dupe
Can you also check for info on these questions?
Thanks,
Aaron
