OpenStack - f5-bigip-lbaas-agent won't start
Trying to install the F5 plugin on a working Icehouse install of OpenStack. This link used to perform the install of the agent. Any help to get the agent working would be greatly appreciated.
[root@network] service f5-bigip-lbaas-agent start ; date
f5-bigip-lbaas-agent start/running, process 6226
Wed Oct 22 07:54:47 MDT 2014
[root@network] ps --pid 6226
PID TTY TIME CMD
[root@network] grep “2014-10-22 07:54” f5-bigip-lbaas-agent.log | sed G
2014-10-22 07:54:47.827 6226 INFO neutron.common.config [-] Logging enabled!
2014-10-22 07:54:47.829 6226 INFO neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LbaasAgentManager with conf
2014-10-22 07:54:47.829 6226 DEBUG neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LogicalServiceCache version 0.1.1 init /usr/lib/python2.7/dist-packages/neutron/services/loadbalancer/drivers/f5/bigip/agent_manager.py:93
2014-10-22 07:54:48.305 6235 INFO neutron.common.config [-] Logging enabled!
2014-10-22 07:54:48.306 6235 INFO neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LbaasAgentManager with conf
2014-10-22 07:54:48.307 6235 DEBUG neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LogicalServiceCache version 0.1.1 init /usr/lib/python2.7/dist-packages/neutron/services/loadbalancer/drivers/f5/bigip/agent_manager.py:93
2014-10-22 07:54:48.726 6244 INFO neutron.common.config [-] Logging enabled!
2014-10-22 07:54:48.727 6244 INFO neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LbaasAgentManager with conf
2014-10-22 07:54:48.728 6244 DEBUG neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LogicalServiceCache version 0.1.1 init /usr/lib/python2.7/dist-packages/neutron/services/loadbalancer/drivers/f5/bigip/agent_manager.py:93
2014-10-22 07:54:49.150 6251 INFO neutron.common.config [-] Logging enabled!
2014-10-22 07:54:49.153 6251 INFO neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LbaasAgentManager with conf
2014-10-22 07:54:49.153 6251 DEBUG neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LogicalServiceCache version 0.1.1 init /usr/lib/python2.7/dist-packages/neutron/services/loadbalancer/drivers/f5/bigip/agent_manager.py:93
2014-10-22 07:54:49.573 6258 INFO neutron.common.config [-] Logging enabled!
2014-10-22 07:54:49.574 6258 INFO neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LbaasAgentManager with conf
2014-10-22 07:54:49.575 6258 DEBUG neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LogicalServiceCache version 0.1.1 init /usr/lib/python2.7/dist-packages/neutron/services/loadbalancer/drivers/f5/bigip/agent_manager.py:93
2014-10-22 07:54:50.050 6265 INFO neutron.common.config [-] Logging enabled!
2014-10-22 07:54:50.051 6265 INFO neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LbaasAgentManager with conf
2014-10-22 07:54:50.051 6265 DEBUG neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LogicalServiceCache version 0.1.1 init /usr/lib/python2.7/dist-packages/neutron/services/loadbalancer/drivers/f5/bigip/agent_manager.py:93
2014-10-22 07:54:50.470 6275 INFO neutron.common.config [-] Logging enabled!
2014-10-22 07:54:50.472 6275 INFO neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LbaasAgentManager with conf
2014-10-22 07:54:50.472 6275 DEBUG neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LogicalServiceCache version 0.1.1 init /usr/lib/python2.7/dist-packages/neutron/services/loadbalancer/drivers/f5/bigip/agent_manager.py:93
2014-10-22 07:54:50.893 6282 INFO neutron.common.config [-] Logging enabled!
2014-10-22 07:54:50.894 6282 INFO neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LbaasAgentManager with conf
2014-10-22 07:54:50.895 6282 DEBUG neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LogicalServiceCache version 0.1.1 init /usr/lib/python2.7/dist-packages/neutron/services/loadbalancer/drivers/f5/bigip/agent_manager.py:93
2014-10-22 07:54:51.300 6289 INFO neutron.common.config [-] Logging enabled!
2014-10-22 07:54:51.302 6289 INFO neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LbaasAgentManager with conf
2014-10-22 07:54:51.302 6289 DEBUG neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LogicalServiceCache version 0.1.1 init /usr/lib/python2.7/dist-packages/neutron/services/loadbalancer/drivers/f5/bigip/agent_manager.py:93
2014-10-22 07:54:51.687 6296 INFO neutron.common.config [-] Logging enabled!
2014-10-22 07:54:51.689 6296 INFO neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LbaasAgentManager with conf
2014-10-22 07:54:51.689 6296 DEBUG neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LogicalServiceCache version 0.1.1 init /usr/lib/python2.7/dist-packages/neutron/services/loadbalancer/drivers/f5/bigip/agent_manager.py:93
2014-10-22 07:54:52.126 6303 INFO neutron.common.config [-] Logging enabled!
2014-10-22 07:54:52.128 6303 INFO neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LbaasAgentManager with conf
2014-10-22 07:54:52.128 6303 DEBUG neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LogicalServiceCache version 0.1.1 init /usr/lib/python2.7/dist-packages/neutron/services/loadbalancer/drivers/f5/bigip/agent_manager.py:93
[root@network] egrep -v ‘(^.*$|^$)’ /etc/neutron/f5-bigip-lbaas-agent.ini | sed G [DEFAULT]
debug = True
periodic_interval = 10
f5_static_agent_configuration_data =
f5_device_type = external
f5_ha_type = standalone
sync_mode = replication
f5_external_physical_mappings = default:1.3:True
f5_vtep_folder = ‘Common’
f5_vtep_selfip_name = ‘vtep’
advertised_tunnel_types = gre
l2_population = True
f5_global_routed_mode = False
use_namespaces = True
f5_route_domain_strictness = False
f5_snat_mode = True
f5_snat_addresses_per_subnet = 1
f5_common_external_networks = True
f5_bigip_lbaas_device_driver = neutron.services.loadbalancer.drivers.f5.bigip.icontrol_driver.iControlDriver
icontrol_hostname = 192.168.1.245
icontrol_username = admin
icontrol_password = admin
icontrol_connection_retry_interval = 10
Giving up on trying to get this working. Is there a plugin for Juno? Cursory google search didn’t reveal anything.
I don’t believe the Juno supported version has been released yet? When you say you had a “working icehouse version”, would you say you had the ML2 plugin and the base LBAAS functioning working?
I got this error when I am trying to start the agent:
2015-01-07 12:10:59.712 42967 INFO neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LbaasAgentManager with conf
2015-01-07 12:10:59.714 42967 DEBUG neutron.services.loadbalancer.drivers.f5.bigip.agent_manager [-] Initializing LogicalServiceCache version 0.1.1 __init__ /usr/lib/python2.7/dist-packages/neutron/services/loadbalancer/drivers/f5/bigip/agent_manager.py:93
Error importing loadbalancer device driver: neutron.services.loadbalancer.drivers.f5.bigip.icontrol_driver.iControlDriver
here is my f5-agent conf:
root@network:/etc/neutron egrep -v "^|^$" f5-bigip-lbaas-agent.ini
[DEFAULT]
debug = True
f5_static_agent_configuration_data = name1:value1, name1:value2, name3:value3
f5_vtep_folder = 'Common'
f5_vtep_selfip_name = 'vtep'
f5_snat_mode = True
icontrol_hostname = 192.168.232.245
[DEFAULT]
debug = True
f5_snat_mode = True
the agent is not running. i run openstack in ubuntu 14.04 and icehouse version.
for the error Error importing loadbalancer device driver: neutron.services.loadbalancer.drivers.f5.bigip.icontrol_driver.iControlDriver
apt-get install python-suds
fix it
