OpenSource tool to capture pool stats
Can you recommend any openSource tool which will allow to Poll the pool stats from the f5 AFM/ASM/LTM device?
Any Open Source tool capable of polling devices by SNMP is capable of monitoring pool stats.
I have “Cacti” polling pool stats amongst other things and there are templates available already got Big-IP stats.
These are the templates I have at the moment so any of the below can be polled by SNMP.
F5 BIG-IP - Global Compression Detail
F5 BIG-IP - Global Compression Stats
F5 BIG-IP - Global Connections
F5 BIG-IP - Global HTTP Requests
F5 BIG-IP - Global HTTP Response Errors
F5 BIG-IP - Global HTTP Responses
F5 BIG-IP - Global packets/sec
F5 BIG-IP - Interface Traffic (bits/sec)
F5 BIG-IP - Memory Utilization
F5 BIG-IP - Pool Connection Rate
F5 BIG-IP - Pool Connections
F5 BIG-IP - Pool Traffic (bits/sec)
F5 BIG-IP - SSL TPS
F5 BIG-IP - TMM CPU Utilization
F5 BIG-IP - v.10 GlobalHost CPU Utilization
F5 BIG-IP - v.10 MultiHost CPU Utilization
F5 BIG-IP - v.10 MultiHost CPU Utilization - 12 Cores
F5 BIG-IP - VS Connection Rate
F5 BIG-IP - VS Connections
F5 BIG-IP - VS Traffic (bits/sec)
F5 GTM - WideIP Statistics
Thanks David, we do run Cacti in our environment but are unable to fetch the pools stats successfully.
do you get a result from SNMPWALK ?? snmpwalk -v 2c -c
