I see the following from the link 404 Page not found | BIG-IP Documentation
“When a new connection is initiated to the virtual server, if an existing server-side flow to the pool member is idle, the BIG-IP system applies the OneConnect source mask to the IP address in the request to determine whether it is eligible to reuse the existing idle connection.”
What eligibility is it and how is it determined?
I wrote a post on exactly that if you are interested, OneConnect with SNAT on F5.
Hope that helps! If it does, please up-vote and select this answer, it would be greatly appreciated!
-Dylan
Thanks for the information. What is F5 recommendation when using oneconnect and CDNs like Akamai and Incapsula and other networks? There is this recommendation from Akami about using oneconnect whenever akamai is involved. Akamai Community
But is this also recommended by F5 ?
I don’t think that F5 has a recommendation for that situation. I can’t locate one anyways.
Until you run into issues, I would follow what Akamai suggests.
-Dylan
