OneConnect Flush Connection Pool
I would like to flush the existing oneconnect pool of HTTP sessions and have them regenerated.
Does the F5 support flush of the oneconnect HTTP sessions or does it requires restart of the whole F5?
thanks,
Asaf
There is no way to only clear OneConnect sessions, but you shouldn’t have to restart. Here are a few things to try instead:
You can clear all connections with the ‘bigpipe conn delete’ command, or with some filter by IP address.
You may also be able to modify the settings on the OneConnect profile, setting MaxReuse to 0 & saving it, then resetting to the original value, or simply remove and re-apply the profile to the virtual server.
hth
/deb
Deb,
if the application guy has security check on server side with client ip address control we can not use oneconnect profile for network based right?
zafer
