I would appreciate any help with the following error I am getting:
“One or more devices are unreachable. Resolve any communication problems before attempting to sync.”
Environment:
Product: Two F5 LTM VE’s
Version: BIG-IP 11.3.0 Build 39.0 VE Trial 11.3.0-HF1 (based on BIGIP 11.3.0HF6)
Running on top of ESXi 5.5.0 (currently on the same ESXi host)
Able to ping from LTM1 to LTM2 over the Management, Internal, External, and HA interfaces
Both devices have each other in their Peer List
Both devices contain a fully populated Device List
Both devices are part of a Device Group with Sync-Failover and Network Failover configured
Have tried resetting the device trust and even rebuilding the F5 LTM’s from scratch a couple times
LTM1 Overview Page
Sync Summary / Status:Awaiting Initial Sync / Summary:The device group is awaiting the initial config sync / Details:Recommended action: Synchronize one of the devices to the group
LTM1:Awaiting Initial Sync / LTM2:Disconnected
The following error shows up under Sync Options: “One or more devices are unreachable. Resolve any communication problems before attempting to sync.”
LTM1:Disconnected / LTM2:Awaiting Initial Sync
Any help getting HA up and running would be much appreciated.
Thanks,
SDTechOps
Can you please run some TMSH commands and paste the output?
tmsh list net vlan
tmsh list net self
tmsh list cm device | grep -v modules
Lastly, initiate a config sync, despite the warning, and paste the relevant lines from the /var/log/ltm file.
Have you tried following existing SOLs? One relevant article is here: 404 Page not found | BIG-IP Documentation
@Hannes Rapp,
Thanks for the reply. Here’s the information you requested.
[root@ust-f5ltm-01:Active:Disconnected] config tmsh list net vlan HA
net vlan HA {
if-index 320
interfaces {
1.3 { }
tag 74
[root@ust-f5ltm-02:Standby:Disconnected] config tmsh list net vlan HA
net vlan HA {
if-index 160
interfaces {
1.3 { }
tag 74
[root@ust-f5ltm-01:Active:Disconnected] config tmsh list net self 192.168.74.1net self 192.168.74.1 {
address 192.168.74.1/24
allow-service {
default
traffic-group traffic-group-local-only
vlan HA
[root@ust-f5ltm-02:Standby:Disconnected] config tmsh list net self 192.168.74.2
net self 192.168.74.2 {
address 192.168.74.2/24
allow-service {
default
vlan HA
[root@ust-f5ltm-01:Active:Disconnected] config tmsh list cm device ust-f5ltm-01.sdtest.local | grep -v modules
cm device ust-f5ltm-01.sdtest.local {
base-mac 0:50:56:8e:44:6a
build 39.0
cert dtdi.crt
chassis-id 420e0720-8e3c-6e11-72fb91cf1a1f
configsync-ip 192.168.74.1
edition "VE Trial 11.3.0-HF1 (based on BIGIP 11.3.0HF6)"
failover-state active
hostname ust-f5ltm-01.sdtest.local
key dtdi.key
management-ip 172.30.54.14
marketing-name "BIG-IP Virtual Edition"
mirror-ip 192.168.74.1
multicast-ip any
platform-id Z99
product BIG-IP
self-device true
time-zone EDT
unicast-address {
effective-ip 192.168.74.1
effective-port cap
ip 192.168.74.1
effective-ip 172.30.54.14
effective-port cap
ip 172.30.54.14
version 11.3.0
[root@ust-f5ltm-02:Standby:Disconnected] config tmsh list cm device ust-f5ltm-02.sdtest.local | grep -v modules
cm device ust-f5ltm-02.sdtest.local {
base-mac 0:50:56:8e:2f:3e
build 39.0
cert dtdi.crt
chassis-id 420e4348-0c60-6c83-510c01f5f0f3
configsync-ip 192.168.74.2
failover-state standby
hostname ust-f5ltm-02.sdtest.local
key dtdi.key
management-ip 172.30.54.24
mirror-ip 192.168.74.2
multicast-ip any
platform-id Z99
product BIG-IP
self-device true
time-zone EDT
unicast-address {
effective-ip 192.168.74.2
effective-port cap
ip 192.168.74.2
effective-ip 172.30.54.24
effective-port cap
ip 172.30.54.24
version 11.3.0
This is all I see in /var/log/ltm during the time frame that I initiated the config sync:
`Apr 9 11:00:01 ust-f5ltm-01 notice mcpd[4828]: 01071431:5: Attempting to connect to CMI peer 192.168.74.2 port 6699
Apr 9 11:00:01 ust-f5ltm-01 notice mcpd[4828]: 01071432:5: CMI peer connection established to 192.168.74.2 port 6699
Apr 9 11:00:01 ust-f5ltm-01 notice mcpd[4828]: 0107143c:5: Connection to CMI peer 192.168.74.2 has been removed
Apr 9 11:17:26 ust-f5ltm-01 notice mcpd[4828]: 01071431:5: Attempting to connect to CMI peer 192.168.74.2 port 6699
Apr 9 11:17:26 ust-f5ltm-01 notice mcpd[4828]: 01071432:5: CMI peer connection established to 192.168.74.2 port 6699
Apr 9 11:17:26 ust-f5ltm-01 notice mcpd[4828]: 0107143c:5: Connection to CMI peer 192.168.74.2 has been removed
As far as the SOLs, I have tried a few of them. I am actually nearing the end of SOL13946 now. So far, the only thing I found was that I didn’t have NTP configured. I went ahead and configured NTP on both LTM’s, rebooted, and even rebuilt the trusts to no avail.
Let me know if I can grab anything else that might help,
SDTechOps
SDTechOps, your F5 HA configuration appears to be good.
I think the only problem you have is that you’re using the handicapped Trial VE license. It has very limited HA capability or no HA support at all (not sure which applies). The only solution I have for you is a recommendation to obtain a proper F5 VE trial software (non-handicapped) from your F5 reseller - they usually come for free and can be used for as long as 60 days.
Your issue appears to be quite common and has been discussed here:
Cheers,
@Hannes Rapp,
Thanks a lot. I hadn’t come across that thread.
What a bummer… I guess HA isn’t supported in my trial version.
I’ll see what I can do about getting a full-featured F5 trial.
Thanks for the help!
SDTechOps
