The impact of one PSU failing is that you are loosing PSU redundancy, if the other one fails as well the device will go down (assuming that the device have 2 PSUs).
Verify, if it was a momentary issue or if the PSU is still down. If its really down, you may try using a different power source, try reseating the PSU and then call the F5 support.
