Hello,
This seemed at first to be quite simple until I received “Requested member (1.1) is untagged on another VLAN”. I’m sure in the end it will be quite simple. I just can’t seem to get the right commands to get it to work.
Simply put, I need to configure interface 1.1 on the F5 with two vlans. I tried searching the forums but couldn’t get the exact information I needed.
Here’s what I tried:
create net vlan vlan_4 { tag 4 interfaces add { 1.1 } }
create net vlan vlan_14 { tag 14 interfaces add { 1.1 } }
01070259:3: Requested member (1.1) is untagged on another VLAN
As you can see I didn’t make it very far. I’ve started to go cross eyed reading some of the forum posts as I understand Cisco lingo but the terms are used different in the F5 domain.
Help
