hello team ,
i have issue regarding upgrade , after i upgraded to 13.1.2 all old backups disappeared .
is it normal behavior ?
Regards , Moustafa
hello team ,
Regards , Moustafa
Hi Moustafa,
Yes this is expected behavior. Images are put on different volumes.
If you want to retain certain files, you may want to touch the cs.dat file. Reference Article
By touching this file, this makes sure your UCS whenever saved, saves the folder/file in the UCS itself. Thus when restoring it. The UCS will restore file/folder as well.
