Ok Signal After SNMP Trap Alert
I am helping develop a system that will consume SNMP trap information from several devices including an F5 LTM. As I’m new to SNMP, I have what might be a noob question for you all. In the documentation for other devices, a trap that informs of an error (such as a fan not working) will either have a stated repeat interval or have a corresponding ok message. What practice does the F5 follow? Is there any other documentation besides http://www.juniper.net/techpubs/en\_US/junos11.1/topics/reference/general/chassistraps-nm-mib.html that I should be looking at?
This might help you to understand how it works…
you may review list of snmp trap bigip sends using mib browser, e.g. ireasoning. it is under bigipnotifications (.1.3.6.1.4.1.3375.2.4.0).
mib file is available at about tab in webui.
Looking over both of those I am still a bit confused.
For example with a Juniper switch (http://www.juniper.net/techpubs/en\_US/junos11.1/topics/reference/general/chassistraps-nm-mib.html)
in the event of a fan failure it woudl send the trap jnxFanFailure 1.3.6.1.4.1.2636.4.1 this is repeated every hour until the issue is resolved at this point a jnxFanOK 1.3.6.1.4.1.2636.4.2 is sent.
With the f5 is there anyway to know that the issue is resolved. Looking at the MIB there are 3 different fan failure traps but none defined that state that there is no longer an issue http://ipmsupport.solarwinds.com/mibs/F5-BIGIP-COMMON-MIB/tree.aspx
I also have not been able to find any documentation on a repeat interval that would let you know the issue is resolved when it is no longer seen repeating.
I also have not been able to find any documentation on a repeat interval that would let you know the issue is resolved when it is no longer seen repeating. as i understand, not every trap has clear trap message. interval depends on how log is generated e.g. by who (daemon or something else).
I found a doc that does have clear codes in it. Redirect Notice
It is odd that most docs do not.
i thought you are using bigip but it is arx, isn’t it??
sorry it is duplicated…
